Outlook 2007: Problem with "Move to Folder >" button on toolbar
ExDC
Using Outlook 2007 on new computer with Win 7. I moved my old .PST file successfully from Win XP machine, but only after having had Outlook on new computer create a new .PST, and THEN moving the old one over, and THEN making the moved one the default and deleting the one Outlook created.
PROBLEM: I have always had a "Move to Folder>" button on my toolbar, and it's there in my new set-up. This is the one that shows the last 10 folders used as destinations - quite a time saver. Now however, those destination folders listed are apparently "stuck" on the original .PST location. If I try to move an email just by clicking on one of them, I get a "Folder not available" message. I can manually move the email, either by dragging and dropping to folder in Navigation bar, or by using right-click. The destination list stays unchanged.
How can I "wipe" that list? I'm pretty sure it's trying to find the folders using the location I used for the PST in WinXP, which of course is not the same as in Win7. I have deleted the button, restarted, added the button again without success. Is there a registry area I can edit? Something else? Thanks.
You are correct – if the list was created on the old computer, it’s looking for the folder in the old path (outlook tracks not Only the pst and folder name, but also the pst location) and they won’t work. They should be replaced as you use new folders though.
To clear the list, you need to edit the registry - http://www.slipstick.com/outlook/clearing-outlooks-most-recently-used-mru-lists/ has the key for this and other MRUs.
But now I have another problem...I may have edited the registry too hard, because now, the old list is gone, but it won't regenerate a new one! (This, after the usual troubleshooting - close everything, reboot, restart Outlook, try again) When the instructions say to delete the value "101f031e" for the Move to Folder history, I deleted that value entirely - should I have simply deleted the contents of the value, leaving it essentially with blank information as a "stub" to repopulate? or is there something else wrong?
Deleting the entire value should have worked - outlook will regenerate it when it's needed. Because it seems to have moved with the pst file, I'd probably run scanpst on the pst.
This is still driving me crazy! I ran scanpst and while it said it found errors and made corrections (is there a log I can check somewhere?) -- the behavior continues...no list of recently used folders.
Have you tried a repair install? Do this from control panel, program and features.
D Problem with MS mail and outlook 2007 OS Windows 8 Using Outlook 1
L Problem with Outlook 2007 with windows 7 Using Outlook 0
G problem loading Outlook 2007 pst file onto windows 7 Using Outlook 1
N Outlook 2007 Categories Problem (Most Recentley Used List Corrupted) Using Outlook 3
C Outlook 2007 Delay Delivery Problem Using Outlook 10
N Automating Outlook 2007 problem with sending mail Outlook VBA and Custom Forms 1
Y Outlook 2007 add-in installation problem on Vista Outlook VBA and Custom Forms 1
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
D Outlook 2007 BCM SQL server problem BCM (Business Contact Manager) 1
