How to copy same text header to multiple emails with custom text column
Chubs
Outlook 2013 64 bit
Exchange Server 2013
I created a custom "notes" column in Outlook 2013 to type short text accents about the email.
Followed slapstick directions and works great.
What I need help with:
I have folders with hundreds of emails each; would like to copy "same" custom text description across all emails into just the custom notes column I created.
Copy/Paste into a single cell is no problem...trying to copy into multiple cells (emails in folder) is what I can't figure out.
Thank you,
Chubs
If you want to copy the contents of the custom field to all messages, a macro might be the easiest, however, you might be able to use a group by view (grouping by the custom field) then drag messages to the group to change the value. This works with most fields but (obviously) not across folders.
The macro at http://www.slipstick.com/outlook/email/sort-messages-sender-domain/ works on the selected messages. Replace the field name and the value with the desired content.
change these 2 lines where it's bolded
strDomain = "Your text goes here"
Set objProp = objMail.UserProperties.Add("your custom field name", olText, True)
objProp.Value = strDomain
Thank you for your response.
I tried the macro suggestion.
I rcv error msg "Object Required".
Can you advise what corrective action might be?
Also, are "quotes" part of the syntax"
Rgds.
Quotes: they are needed to wrap the text where I have them in the sample above.
Assuming the problem isn't with the quotes, post the code here and I'll see what is wrong.
Thank you. Here's the code:
Sub cisco_macro()
strDomain = "chubs: general"
Set objProp = objMail.UserProperties.Add("Notes", olText, True)
That worked; compiled fine.
I ran the macro but nothing happened.
Do I have to run the macro from the specific outlook folder and select specific msg's?
Thks.
Select the message you want to change then run it. It can be changed to use a selected folder or a specific folder, but as written, it works on selected messages.
Oh my gosh!
Works like a charm. Thank you so much.
This has saved me a ton of work Diane.
Regards and Best,
Chubs
I have this macro working on my custom field name perfectly.
I'd like to use this for the "Subject" column (field) in the main email view of Outlook 2013.
Tried inputting "Subject" in custom field name but no-go.
Is there a way to perform this function with modification to above macro?
Regards,
Chubs
[DOUBLEPOST=1426200084][/DOUBLEPOST]Hi,
Regards,
Chubs
Subject isn't a custom field - you'd use
item.subject = "whatever"
C Copy from one Profile to another Using Outlook 0
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
I How to make a copy of a task Using Outlook 8
