HOW TO GET PROPERTIES FOLLOW UP
oliv-
I need to get properties from an Outlook Mailitem to know if there is a "follow up" (task for me) on this Email and if right i want to get reminder details.
Sub baba_Active_item()
    Dim oItem As Object
    Set oItem = ActiveInspector.CurrentItem
    Dim pa As Outlook.PropertyAccessor
    Const TASK_REMINDER_TIME = "http://schemas.microsoft.com/mapi/id/{00062008-0000-0000-C000-000000000046}/0x00008502"
        Set pa = oItem.PropertyAccessor
MsgBox " Reminder =" _
          & pa.GetProperty(TASK_REMINDER_TIME)
= error "-2147221246 (80040102)" Cannot get property..
Why not just check the .IsMarkedAsTask value? If it's true, the item is flagged. Use .ReminderTime to get the reminder time.
  Dim oItem As Object
  If oItem.IsMarkedAsTask = True Then
       MsgBox " Reminder = " & oItem.ReminderTime
oliv-
Because i want to test it before is sent, (=oItem.IsMarkedAsTask = False )
AFAIK, you can't read the reminder and flag property until after the message is sent, even using propertyaccessor.
oliv-
Thank you for your responses and your time.
