pr_container class missing
kevin eaton
hi diane, firstly thanks for your work with scripts and mfcmapi etc, it has helped me out previously with imap to exchange migrations.
however, this time, i have a weird issue. i have 9 mailboxes with thousands of folders from gmail. ive connected via imap, and exported to a pst.for each account.
i was then going to use your script to change the PR_CONTAINER_CLASS attribute prior to importing to exchange, but i thought id check one pst file first with mfcmapi manually.
the property PR_CONTAINER_CLASS does not exist at all in any of the folders. im in the middle of the migration and the customer is getting a bit twitchy - any chance you can tell me what i should do?
the mailbox in question im looking at with mfc mapi was connected to gmail via outlook 2007. is it because of 2007 that this has occurred? thanks in advance for your help.
the two files attached are the mfcmapi display for a folder in that mailbox. slipstick1 is the left hand side, slipstick2 is the right hand side of the window. (screen wasnt wide enough to do screenshot of whole width at once)
well, just an update to this - it looks like it doesnt matter, outlook seems to assume by default that it is a mail folder. id still love to know why the property doesnt exist though!
R Class Modules and WithEvents Outlook VBA and Custom Forms 2
S Unable to change Message Class Outlook VBA and Custom Forms 0
S Changing Message Class Outlook VBA and Custom Forms 4
Witzker HowTo Change message Class of contact form Outlook VBA and Custom Forms 0
P Message Class keeps changing back to IPM.Contact Outlook VBA and Custom Forms 2
J Outlook 2007 - Change Message Class for all Items in Folder Outlook VBA and Custom Forms 1
L Moving Message Class email via script and Rule Outlook VBA and Custom Forms 3
1 Outlook Message Class Exchange Server Administration 3
M RDO: using TypeOf to determine [OOM] Class Outlook VBA and Custom Forms 1
H How to make hourglass and change back to default in Outlook class ? Outlook VBA and Custom Forms 3
K cannot instantiate abstract class - Compiler error. Outlook VBA and Custom Forms 3
S Failed to create an RDO session instance: Class not registered Outlook VBA and Custom Forms 1
S Changed Message class; forms with data resist. Outlook VBA and Custom Forms 5
T Changing Icon of message class Outlook VBA and Custom Forms 1
J Outlook 2021 ScanPST errors (yet again ... sorry): repair button missing Outlook 2021 Using Outlook 5
M Outlook calendar is missing Using Outlook 2
Witzker Open Contact missing in Outlook 2019 Using Outlook 2
M Simplified ribbon missing Using Outlook 3
T Missing Folder in Outlook.com Using Outlook 3
T 3 months of archived e-mail is missing Using Outlook 1
O Outlook 365 - Toolbar - Close all items - missing? Using Outlook 3
V Items missing in Sent folder Using Outlook 10
A Missing context menu on Location field Using Outlook 2
S Missing Outlook calendar and contacts Using Outlook 0
T Missing Outlook subordinate folder Using Outlook 0
J Tasks - the missing link... for me at least. Using Outlook 4
GregS Dropdown address list missing Using Outlook 1
J Control Panel Mail (settings) icon missing Using Outlook 2
P Missing Folder Using Outlook 1
Diane Poremsky Shortcuts and the Missing Outlook:// Protocol Using Outlook 0
Diane Poremsky Task Request Status Update Address Missing Using Outlook 0
Diane Poremsky Check for missing attachments before sending a message Using Outlook 1
O Missing guide "Move an Outlook Personal Folders .pst File" Using Outlook 4
