Create Macro for hyperlink(email) in message body
Alfredo Duran
I would like some help with a macro. I receive an email from dig alerts everyday and I have a rule that sends them to my task folder. When I open the email, I would like to create a macro so when I click on the hyperlink that is included in the message body, runs the macro and sends it to a template that will put the hyperlink on the To box, the subject will say "USA Dig Alert Notification" and the Body will have "NO CONFLICT" and the original message below that. I will upload some files to see what I mean. Any help is really appreciated. Thank You.
Alfredo Duran
Ok maybe this would be much easier. How do I reply to a link in an email to open a template I have created already?
Michael Bauer
Getting the mouse click on the link would be difficult. Instead parse the body of the email for the link and if found, call the Reply function for that email. For parsing the Body either use the Instr function if you know what words to look for, or use regular expressions. The latter isn't easy for most beginners, search this forum for samples, for sure Diane has some for you.
Alfredo Duran
Thanks Michael. I was able to piece together a code that did partially what I wanted. It put the email from the original email body into a reply email in the To: field and copied the original email into the new reply email.Now I just need help with changing the subject to say "USA Dig Alert" and I want to include "No conflict" also in the body along with the original email. I will include the code to see if someone can suggest how to go about it.
Alfredo Duran
Sub ReplyTest()
Dim objItem As Object
Dim intLocAddress As Integer
Dim intLocCRLF As Integer
Dim strAddress As String
Dim objReply As MailItem
Set objItem = GetCurrentItem()
If objItem.Class = olMail Then
' find the requestor address
strAddress = ParseTextLinePair(objItem.Body, "Requestor Email:")
' create the reply, add the address and display
Set objReply = objItem.Reply
objReply.To = strAddress
objReply.Display
Set objReply = Nothing
Set objItem = Nothing
Function ParseTextLinePair(strSource As String, strLabel As String)
Dim intLocLabel As Integer
Dim intLenLabel As Integer
Dim strText As String
' locate the label in the source text
intLocLabel = InStr(strSource, strLabel)
intLenLabel = Len(strLabel)
If intLocLabel > 0 Then
intLocCRLF = InStr(intLocLabel, strSource, vbCrLf)
If intLocCRLF > 0 Then
intLocLabel = intLocLabel + intLenLabel
strText = Mid(strSource, _
intLocLabel, _
intLocCRLF - intLocLabel)
intLocLabel = Mid(strSource, intLocLabel + intLenLabel)
ParseTextLinePair = Trim(strText)
End Function
Set objApp = CreateObject("Outlook.Application")
Case "Explorer"
Case "Inspector"
Set GetCurrentItem = objApp.ActiveInspector.currentItem
Case Else
' anything else will result in an error, which is
' why we have the error handler above
Set objApp = Nothing
End Function
Michael Bauer
To add something at the beginning of the Body property, write this
objReply.Body = "new stuf" & vbcrlf & objReply.Body
As to the Subject property, guess how you would set that one.
Alfredo Duran
Ok I got it to work Michael. Now how change I change the font color on the objReply.Body = "NO CONFLICT WITH SEWER MAINTENANCE FORCE MAIN" to a red font. Thanks for the help!
Sub ReplyTest()
'this gets the subject from original email
strAddress = ParseTextLinePair(objItem.Body, "Email: ")
'strAddress = email in original body of Dig Alert
'Set objReply puts RE: xxxxx into subject field objItem.Reply
'puts email address from orig. email into new email To: field
'removes the Re: in the subject
objReply.subject = "USA Dig Alert"
objReply.subject = Replace(objReply.subject, "Re:", "", , , vbTextCompare)
strStyle = "'font-family:" & Chr(34) & "Calibri" & Chr(34) & ";color:red'"
objReply.Body = "NO CONFLICT WITH SEWER MAINTENANCE FORCE MAIN." & vbNewLine & vbNewLine & vbNewLine & objItem.Body
objReply.Display
Case "Explorer"
Set GetCurrentItem = objApp.ActiveExplorer.CurrentItem 'Selection.Item(1)
Case "Inspector"
Case Else
End Function
intLocLabel = InStr(strSource, strLabel) 'strLabel adds email in body to To: Field
intLocLabel, _
End Function
Michael Bauer
In that case you need to use html instead of plain text. Replace .Body by .HTMLBody, and add strStyle as a css style attribut to the text.
Alfredo Duran
Thanks Michael. Figured it out and it has been working with no glitches. Now I have another problem. I share my task folder with other co-workers. They use this macro to reply to my emails that are shared on the task folder. Work will not allow me to delegate access to them so they can send on my behalf, so can I add something to the macro to change the From: field to them instead of from me? Here is the current macro I have.
Sub Reply()
objReply.Display
Case "Explorer"
Case "Inspector"
Case Else
End Function
intLocLabel, _
End Function
Michael Bauer
If you're connected to an Exchange server, you can use the SentOnBehalfOfName property.
