outlook mail merge -rich text
iwshim
Outlook 2013 32 bit
I am mail merging from MS word to outlook. It seems all my messages are being sent in html and not rich text. my pictures are sent as attachments (not what I want).
Solutions?
Outlook will default to using HTML to internet addresses as only outlook can open RTF. The image would be wrapped in a winmail.dat file if they didn't use Outlook.
What types of email accounts are you sending to? If you inserted the image into the word doc, it will be embedded in the email but some email clients (like gmail) show it as an attachment - even outlook will show the attachment icon until the message is rendered.
Students - they are all different. gmail, academia, Korean domains. ect.
I think everything is ok.
iwshim mail merge and add the contact picture outlook 2013 Using Outlook 3
W Combine Mail Merge to Distribution List with Auto Attachments - Outlook 2007 Using Outlook 1
A Outlook 2007 Mail Merge not working anymore Using Outlook 1
H Outlook - Mail Merge Outlook VBA and Custom Forms 1
P Limited Support for 3rd Party Mail in new Outlook? Using Outlook 1
ThinkToday Calculate reply time of outlook mail Using Outlook 1
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
S Outlook not receiving mail Using Outlook 1
B Outlook - Mail from safe senders list being sent to Spam Folder Using Outlook 0
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
T Probem with junk mail folder in new account in Outlook Using Outlook 0
GregS Outlook mail arrives in batches, sometimes hours late Using Outlook 1
T Outlook 2016 cannot connect after transition to Outlook Mail Using Outlook.com accounts in Outlook 4
N Outlook People Pane - Sent Mail Using Outlook 1
L pin to Outlook move mail Using Outlook 2
M Outlook Mail Using Outlook 3
Diane Poremsky Junk Mail Filtering in Outlook Using Outlook 0
I Collecting mail address from GAB and adding to Outlook Task Using Outlook 2
Diane Poremsky Internet Mail Issues with Outlook Using Outlook 0
