Excel Files Won't Display in Reading Pane
OS Version(s)
  1. MacOS
  2. Windows
  3. iOS
  4. Android
In Outlook for Mac 2011 (version 14.6.3):
1) Make sure Reading Pane is visible and where you want it. (View menu > Reading Pane > select location)
2) Set this as your preference. (View menu > Arrange By > Make this the Default View)
3) Repeat sub folders as needed or desired.
P Excel 2010 can't open .xlsx files Using Outlook 1
E Extract excel files from outlook Outlook VBA and Custom Forms 2
M VBA Send Sales reports using .oft files, originate in Outlook or Excel? Using Outlook 5
T Word attached files open Word. Excel files open Picture Manager!! Using Outlook 2
K Prevent sending Excel files as attachements Outlook VBA and Custom Forms 1
L Error when exporting Sent Mail to Excel Outlook VBA and Custom Forms 6
P OT: Need website like this one, but for Excel Using Outlook 0
D Cannot populate certain UserProperties in Outlook from Excel Outlook VBA and Custom Forms 2
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
C Pull Outlook shared calendars items from Excel Outlook VBA and Custom Forms 4
S How to export urls from email to excel and check the status of the url ? Using Outlook 5
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
K Update Appointment category when changed in Excel Using Outlook 3
D Paste Excel table into Outlook message Outlook VBA and Custom Forms 6
D Retrieving Tables from outlook to excel Using Outlook 14
nathandavies Email Details to Excel & Save as .MSG on one macro - combination of 2 macros Outlook VBA and Custom Forms 3
T Outlook Calendar 2016 import Excel Using Outlook 1
N Lookup Value From Excel and Reply With Matching Value Using Outlook 0
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
Diane Poremsky Importing Lists from Excel to Outlook Using Outlook 0
N Paste content to Excel when .txt file (attachment) is opened Outlook VBA and Custom Forms 1
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
M Linking Excel Cell to Shared Contacts Outlook VBA and Custom Forms 7
