Outlook PST not opening
Reyeat7
Hi;
When I attempt to open outlook I get an error:
Cannot start Microsoft Office Outlook. Cannot open the Outlook window. The set of folders cannot be opened. Errors have been detected in the file C:\Documents and Settings\Sabrina\local settings\application data\Microsoft\outlook \outlook.pst. Quit outlook and all mail-enabled applications and the use the inbox repair tool (scanst.exe) to diagnose and repair errors in the file for more information about the inbox repair tool see help.
I have attempted to repair the .pst file using scanpst but it fails. Do you know another utility preferably a free one which I can use to repair the file.
From my stand of point, you should try some other manual ways to sort out the bug before going for a software. This error just does not occur becaue of corrupt PST file. It also popped out when the settings of navigation file gets corrupted or because of corrupted Outlook profile and others too.
Try to run this command into cmd box:
outlook.exe /resetnavpane
Apart from it, re-configuring Outlook profile could help to fix this error. At last, if these troubleshooters do not help, you can go and find third party utilites. Truth be told, if you are looking for any third party utility, then there are very minial chances that you will get a software free of cost. But yes, a few of them provide demo versions and you can have from their official sources:
These are some vendor’s names that I got from CNET vendors lists:
Stellar Phoenix
SysTools Group
Remo Repair
Kernel
DataNumen
Feel free to ask further!!!
U .pst file error at opening outlook Using Outlook 1
G Opening pst files in different versions of outlook Using Outlook 2
H Opening .PST archive files in Outlook 2007 Using Outlook 10
K Moved pst to new computer, now Gmail not coming into Outlook Using Outlook 7
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
HarvMan Outlook 365 PST Report Using Outlook 1
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
DariTrevino MIcrosoft Outlook PST file cannot repair Using Outlook 1
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
J Outlook 2016 - use of old PST file - will all emails be downloaded or only latest?? Using Outlook 1
P Moving Outlook.pst & archive1.pst Using Outlook 3
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
chai1949 pst file in outlook 2016 Using Outlook 3
Liz Schneider PST from Outlook 2013 is now IMAP folders in 2016 Using Outlook 10
Diane Poremsky Remove a password from an Outlook *.pst File Using Outlook 3
GregS Import from Outlook.com .ost to IMAP .pst? Using Outlook 3
O Missing guide "Move an Outlook Personal Folders .pst File" Using Outlook 4
Diane Poremsky How to repair a damaged Outlook Personal Folders file (pst) Using Outlook 0
S Portable MS Outlook or similar using PST Using Outlook 0
Z Importing PST files from Outlook 07 to Outlook mac Preview Using Outlook 1
B No permission to access Outlook.pst file Using Outlook 1
S How to restore corrupted PST file over 2GB in Outlook 2007 Using Outlook 2
G pst file restore Outlook 2013 from HTC One M9 Using Outlook 1
R can I transfer outlook data from old pc by using .ost file instead of the .pst Using Outlook 5
L what is safe size for pst of Outlook 2013 via Office 365 exchange? Using Outlook 1
J Outlook won't open. PST file busy. Using Outlook 3
