Outlook 2016 not opening
Mistyfied
Outlook 2016 64 bit
Outlook.com (as MS Exchange)
I have recently installed Outlook 2016 and have added my Outlook.com account. I've tried to set up my icloud account that was unsuccessful.
When I've tried to open Outlook again and am prompted to enter the icloud details. I know the server details are incorrect so I am prevented from accessing Outlook.
I've searched for the .pst file and deleted it, but that did not cure the problem.
I've uninstalled/rebooted/installed twice but still no joy as I am still prompted to enter the icloud details.
Can anyone give me some advice as to how to fix this?
Close Outlook. Go to Control panel, search for Mail. Edit the profile to remove the iCloud account (or edit it). That should fix it...
Incoming IMAP mail server: imap.mail.me.com
Outgoing SMTP mail server: smtp.mail.me.com
Username: Use your iCloud alias or your full iCloud email address.
Password: Your iCloud password
In More Settings, check these settings:
Outgoing Server tab: Use SMTP authentication.
Advanced tab: Use SSL (or Auto) for both incoming and Outgoing servers. Incoming port is 993, Outgoing port is 587.
Many thanks for your advice. All working OK following your clear instructions.
A Outlook 2016- unable to have all subfolders expanded when opening outlook Using Outlook 11
M Outlook 2016 still feature updating Using Outlook 0
S Outlook 2016 and Acrobat PDFMaker Office COM Addin Using Outlook 0
W Outlook 2016 MSI - Possible to make work with O365 modern Auth & Win7? Using Outlook 4
J Outlook 2016 Trying to get Outlook 2016 to work with Office 365 Using Outlook 0
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
bhamberg Shortcuts in Folder Pane (Outlook 2016) Using Outlook 19
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
M Office 2016 Outlook is forgetting passwords Using Outlook 15
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
A Outlook 2016 in Cached Mode Using Outlook 1
N Outlook 2016 Folder Icons Look Using Outlook 0
