Inbox field customization
eds
Outlook 2016 64 bit
My company uses the Job Title field extensively.
I would like to be able to add that as a filed in the main inbox view but can find no category header that will allow this.
Can this be done?
The only way to add it to the field as field would be using VBA and you'd need to run the macro on the contacts to set it. I'm not sure how 'stable' it would be - syncing or editing contacts could reset to a a default value.
This macro changes the fileas: Bulk Change File As Format for Contacts
L How to show Delivered-To field in Inbox Using Outlook 1
D Show opportunity field in mail inbox BCM (Business Contact Manager) 1
F Outlook 365 Group INBOX by date but not by date and time Using Outlook 1
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
S Format Inbox Using Outlook 0
P Emails assigned with a certain category (within a shared inbox) to be copied to a specific folder. Outlook VBA and Custom Forms 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
E Outlook 2016 Inbox search bug Using Outlook 1
LolaArrabal My huge inbox folder Using Outlook 2
