Move Emails between Folders in Separate Mailbox
Outlook 2016 64 bit
Greetings,
I am trying to move all messages in one subfolder to another. Actually I have to do that twice but I can adapt the code myself. My trouble is that I'm far more adept with Access VBA than Outlook VBA. Also, the message folders (current and target) aren't within my own mailbox, they're within another in my profile (not even sure if I'm using the right terminology). I've included a snapshot of the mailbox layout below. So within the TDEM Contracts mailbox(?), I need a way to move all messages from Daily Emails to "daily_log_holding_area". Once I manipulate it and run the reports I need to, I then need to move them from there to "logged_emails". Certainly I could just click and drag but with 100's - 1,000's needing to move each day I'm forced to move them in multiple chucks, which just takes to much attention/time/steps. I'm able to find similar code to what I need, but I can't seem to adapt it to the fact that it's not my own inbox. It may just be a syntax thing I'm unfamiliar with.
Any help would be greatly appreciated!
David
Based on the screenshot, it looks like it is a shared mailbox (the display name instead of an email address)
You'll use the method at Working with VBA and non-default Outlook Folders
This is the inbox:
Set InboxFolder = NS.GetSharedDefaultFolder(objOwner, olFolderInbox)
reference the subfolder of inbox:
Set subFolder = InboxFolder.folder("folder name")
This is the inbox:
Thanks Diane! A quick followup question. Though it's not in the screenshot, I have multiple shared mailboxes that I can access. Will the code you've provided be able to determine the right one or will additional code be necessary? Thanks!
You'll need to repeat the code. Depending on how the macro is written, you'll either use different object names and basically repeat the code below, or loop and use a different recipient name each time. This would work with an array or select case (and cut down on the amount of code you need to use.)
You could use a small macro that sets the mailbox name (and even the folder names to use), then call one that does the move.
 Set objOwner = NS.CreateRecipient("maryc")
    objOwner.Resolve
If objOwner.Resolved Then
   'MsgBox objOwner.Name
Set newCalFolder = NS.GetSharedDefaultFolder(objOwner, olFolderCalendar)
    objOwner.Resolve
Well, I've made some great progress but somewhere I'm screwing up. I have the following code, though the couple of examples you sent had some slightly different naming conventions so my inexperience may be at fault if I've incorrectly pieced them together. Every time I run this code:
Sub MoveMail()
    Dim objNamespace As Outlook.NameSpace
    Dim objVariant As Variant
    Dim lngMovedItems As Long
    Dim intCount As Integer
    Dim strDestFolder As String
    Dim inboxSourceFolder As Outlook.MAPIFolder
    Dim DestsubFolder As Outlook.MAPIFolder
    Dim SourcesubFolder As Outlook.MAPIFolder
    Set objOutlook = Application
    Set objNamespace = objOutlook.GetNamespace("tdem")
    Set inboxSourceFolder = objNamespace.GetDefaultFolder(olFolderInbox)
    Set SourcesubFolder = inboxSourceFolder.Folder("Daily Emails")
    Set DestsubFolder = inboxSourceFolder.Folder("daily_log_holding_area")
    For intCount = SourcesubFolder.Items.Count To 1 Step -1
        Set objVariant = SourcesubFolder.Items.Item(intCount)
        DoEvents
              objVariant.Move DestsubFolder
              'count the # of items moved
               lngMovedItems = lngMovedItems + 1
    ' Display the number of items that were moved.
    MsgBox "Moved " & lngMovedItems & " messages(s)."
Set objDestFolder = Nothing
It gives me the most unhelpful error message "Sorry, something went wrong. You may want to try again." When I hit debug it points me to the row that begins "Set objNamespace". For background, I deviated from your example a bit because I want all the emails in a folder moved, regardless of their characteristic. I should also point out that "TDEM" is the alias used for the account. The email prefix before the @ is "tdem.contract", I've tried both and gotten the same error message, I wasn't sure which to use.
Thanks SO much. This has been very helpful for me and I greatly appreciate your feedback and assistance.
i have not tested this yet - but i think i fixed all the errors - i need to figure out which test account is shared with another before i can test it. :)
The folder tree in the shared box will be
-Inbox
-- Daily Emails
-- daily_log_holding_area
Sub MoveMail()
    Dim NS As Outlook.NameSpace
    Set NS = objOutlook.GetNamespace("MAPI")
'### Get Shared
    objOwner.Resolve
Set inboxSourceFolder = NS.GetSharedDefaultFolder(objOwner, olFolderInbox)
'### end get shared
    Set SourcesubFolder = inboxSourceFolder.Folders("Daily Emails")
    Set DestsubFolder = inboxSourceFolder.Folders("daily_log_holding_area")
        DoEvents
-Inbox
-- Daily Emails
Sub MoveMail()
'### Get Shared
    objOwner.Resolve
'### end get shared
        DoEvents
Thank you so much. The folder tree is exactly right. When I tested the code, it threw "Object Variable or With block variables not set" and directed me to the "Set SourcesubFolder" line. Thank you again so much for all your help!
i'm getting a different error on that line - object cant be found (I just created the folder but that shouldn't make a difference)
ETA: opened the mailbox in another profile and the folders i added didn't sync up. that explains my error.
Ok.. once i got the folder issues solved, this worked to move mail from Daily Emails to the log holding folder.
Sub MoveMail()
    Dim destSubFolder As Outlook.MAPIFolder
    Dim sourceSubFolder As Outlook.MAPIFolder
'### Get Shared
    Set objOwner = NS.CreateRecipient("replies")
    objOwner.Resolve
   MsgBox inboxSourceFolder.FolderPath
'### end get shared
  Set destSubFolder = inboxSourceFolder.Folders("daily_log_holding_area")
  Set sourceSubFolder = inboxSourceFolder.Folders("Daily Emails")
    For intCount = sourceSubFolder.Items.Count To 1 Step -1
        Set objVariant = sourceSubFolder.Items.Item(intCount)
        DoEvents
              objVariant.Move destSubFolder
Hey Diane,
I must be doing something else wrong because I'm still getting that error message that you're not. I've attached two pictures that show what's going on. One is the error message and the other is what going into debug shows. Thank you again so much for your help!
Sub MoveMail()
'### Get Shared
    objOwner.Resolve
'### end get shared
        DoEvents
Not sure if this is my issue but I have multiple shared mailboxes. How does the code direct to a specific mailbox. I see it get the folders of course, but not the inbox. Again, I've an early novice with Outlook so maybe it does. Thanks!
Does that folder exist? if you hover of the yellow words, what does it show?
This is where it directs the shared box:
This is one way to handle running it on multiple folders. The alias can be the alias, the display name, or the email address.
Dim strAlias As String
Sub MoveMail()
strAlias = "replies"
DoMoveMail
strAlias = "olSales"
DoMoveMail
Sub DoMoveMail()
'### Get Shared
    Set objOwner = NS.CreateRecipient(strAlias)
    objOwner.Resolve
'### end get shared
        DoEvents
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
B Move emails from one account to another Outlook VBA and Custom Forms 2
N Move emails of same conversation to same subfolder Using Outlook 6
B Macro to manually move selected emails to network folder Outlook VBA and Custom Forms 1
K VBA to move emails in folder to a windows folder Outlook VBA and Custom Forms 2
N Move red and unflagged emails to subfolder Outlook VBA and Custom Forms 1
I vba scrip to move emails based on long keywords list Outlook VBA and Custom Forms 0
V move emails to windows folder and show sender details Using Outlook 7
G email returns after running macro to move emails Outlook VBA and Custom Forms 1
S How can I create a rule to move inbound emails from any of my contacts out of Inbox? Using Outlook 1
S Macro to print & move selected emails? Using Outlook 3
H Rule to move emails based on subject and content Outlook VBA and Custom Forms 1
H Move outlook emails >90 days to shared drive (Desktop) Folder Outlook VBA and Custom Forms 5
O Script to move emails to a folder based on various possible keywords Outlook VBA and Custom Forms 11
S how to keep "To" when move sent emails to other folder Using Outlook 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
R Move sent items emails to hard disk Using Outlook 10
B OUTLOOK 2013: How Do I Move Emails to Folders stored on my Hard Drive? Using Outlook 3
S Outlook macro to move replied / forwarded emails to a seperate folder Using Outlook 1
C Help with a Macro to move emails to a different PST data file Using Outlook 4
A rule to move emails to a folder then want to delete them from that folder 2010 Using Outlook 5
V Move old emails or emails with large attachments ? Outlook VBA and Custom Forms 1
J move contents from hundreds of emails into excel Outlook VBA and Custom Forms 4
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 3
B Outlook 2019 Automatically move email after assigning category Using Outlook 4
M Move command Outlook VBA and Custom Forms 11
Commodore Unable to move message Using Outlook 3
J Dopey move - deleted profile Using Outlook 1
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
