How Do I insert images in and Auto Reply
Ross Meyer
Outlook 2016 64 bit
How do I insert an image in an Auto Reply Message in Outlook 2016? I tried using a template from a rule and when I got the auto reply i didn't see the image or signature inside.
Template rule should work - unless it is sending only plain text reply, then you need to use a run a script rule.
Run a script rule: Autoreply using a template
Signatures should be added to the template - they won't be added when its sent.
Ross Meyer
Outlook 2016 64 bit
Just found out it's an office 365 server problem. That's what the company is using
You could try inserting an image on a website instead of from your hard drive (so it is linked rather than embedded).
