converting mail enabled users to mailbox enabled users
W
WE1BTg
How do you convert mail enabled users to mailbox enabled users on E2K7??
Rich Matheisen [MVP]
On Wed, 13 May 2009 13:36:12 -0700, XMAN
You disable the user in the EMC and then create a mailbox for them in
the EMC.
Rich Matheisen
brijesh
On May 14, 6:50 am, "Rich Matheisen [MVP]"
> the EMC.
> -> Rich Matheisen
go to the ADUC right click on the user select exchange task and select
mail enabled tab..
O
Oliver Moazzezi [MVP]
> mail enabled tab..
You do not mailbox enable users via ADUC in Exchange 2007. This is managed
through the EMS or EMC.
You can mail disable a legacy user before mailbox enabling them in ADUC
however.
Oliver
E
eileen.shepard@gmail.com
On 14 May, 07:53, "Oliver Moazzezi [MVP]"
> >mail enabled tab..
> however.
> Oliver
How is the conversion of a mail-enabled user to a mailbox-enabled user
best done via scripted methods (2007)?
Eileen
On Thu, 14 May 2009 06:52:52 -0700 (PDT), "eileen.shepard@gmail.com"
> > >mail enabled tab..
> > however.
>> Oliver
It could be as easy as "disable-mailuser|new-mailbox
<some-parameter-values>". But if there are properties that ou want to
preserve that would be removed by the disable-mailuser then you'll
have to preserve those property values before you disable the user.
You'd then use the saved properties to populate the new mailbox
properties.
And, if you're going to be scripting, don't be suckered by the "I can
do this in one line of code" school of thought. There are things that
can, and will go wrong. If you don't check for errors after the
operation you may -- no, _will_ -- be surprised at some point by
things that have gone wrong.
Rich Matheisen
