Contact Business card view
jwkde
Outlook 2007
Any reason why my outlook contacts in business card view has every card truncated?
No, but you are the second person with the problem.. not sure if the other person was using icloud, so it might be a clue - at least it gives me something to check. Neither myself nor microsoft could repro it after the first complaint and we blamed something goofy with hi-res screens.
Did this just start recently?
Oh, and what is your version and build # of Outlook.
That's the same as on my laptop. Did you customize the display settings?
jwkde
Outlook 2007
no same display settings i have been using for over a year.
Are you on an insider build? If you have File, Support, Contact Support. Use it to contact support - and if they ever figure out what is going on, besure to let me know.
I have been asked to have you restart outlook and see if it's better now.
jwkde
Outlook 2007
Seems that it was a conflict with an NVDIA geoforce. Once I uninstalled that Outlook contacts are fine Thanks for your help
Thanks. Apparently there was also an issue - they didn't tell me what, so it could have been related to the nvida or it could have been a coincidence - they are able to send updates or commands based on issues discovered through support requests, crash reports etc. They found something and switched it off, but it wouldn't take effect until you restarted outlook.
