Inbox Sub-Folder - Web
Tomohawk
I have noticed a sub-folder in my inbox, which is called Web. I have no idea how it got there, what it is used for, how it gets populated or how to manage/delete it (or even if I should)
This is in a POP account? It's not a default Outlook folder and if you aren't using imap, not a folder your mail server created. An addin may have added it - check the addins in File, options, addins.
Can you right-click and Delete it?
D User cannot move email messages within Outlook Inbox folder and sub-folders. Using Outlook 0
D Sub folders of my Inbox collapsing Using Outlook 0
C Unread email count not displaying on Inbox sub-folders Using Outlook 0
W Shared inbox sub folders not visible when moved Using Outlook 3
T Make sub folders of inbox appear BOLD when new mail arrives Using Outlook 10
F Outlook 365 Group INBOX by date but not by date and time Using Outlook 1
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
S Format Inbox Using Outlook 0
P Emails assigned with a certain category (within a shared inbox) to be copied to a specific folder. Outlook VBA and Custom Forms 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
E Outlook 2016 Inbox search bug Using Outlook 1
