PST recovery
TedMi
I need to recover a corrupted .pst file created by either OL 2002 or 2003
(currently using 2007). Tried Scanpst & Stellar's Repair; they both report
"not a pst file." Recovery ToolBox processes the input but extracts 0
folders and files.
Anyone know of a more forceful tool?
-TedMi
C
Christian Goeller
TedMi, you wrote on Tue, 24 Mar 2009 15:48:12 -0400:
> folders and files.
Well, when this tools couldn't recover the file, I think you'll be out
of luck.
Datanumen has a recovery tool but it may not do any better than the others.
See http://www.slipstick.com/problems/pst-repair/repair-a-damaged-personal-folders-pst-file/ for Advanced Outlook
Recovery and other tools.
"TedMi" <tedmi@hotmail.com> wrote in message
news:uONG5lLrJHA.2552@TK2MSFTNGP04.phx.gbl...
> folders and files.
> Thanks.
> -TedMi
folders and files.
-TedMi
TedMi -
Were you ever able to resolve this issue? I'm having the exact same problem - and neither scanpst nor stellar have helped. I cringe at the price tag on the software referral given by diane.
I would appreciate hearing back from you.
Wendy
Roady [MVP]
There are several other recovery tools as well but you're right; most don't
come cheap. Their price depends on what kind of issues they can fix and
whether you need a business or a home license. The price is relative though;
it all depends on the value of the data that you need to recover.
Home licenses are cheaper for OutlookFIX;
http://addins.howto-outlook.com/cimaware_outlookfix
Advanced Outlook Repair is an excellent recovery program as well but more
expensive;
http://addins.howto-outlook.com/datanumen_outlookrepair
If you decide to order, use "DNC-PUXB-HT" to get a discount.
IIRC; both offer a trial version so that you can see if they can actually
recover data from your pst-file.
"sophie2000" <sophie2000.3wh3wa@no-spam.invalid> wrote in message
news:sophie2000.3wh3wa@no-spam.invalid...
> > 2003
> > report
> > folders and files.
>> Thanks.
> > -TedMi
> TedMi -
> Wendy
W
wangdong
I have met the same problem some days before. I found a good tool
called Advanced Outlook Repair. You can download a free demo version
at http://www.datanumen.com/aor/aor.exe . I think it is a useful
repair tool for you. It is easy to recover your PST file by using its
wizard. It is a powerful tool to recover messages, folders and other
objects from corrupt or damaged Microsoft Outlook PST files.
Detailed information about Advanced Outlook Repair can be found at
Wangdong
JNPT
What Kind of problem exactly you faced while repairing corrupt .pst file
using Stellar's Outlook PST repair Tool. It may be because of some technical
issue.
Either you can try the new version of the software which is more efficient
and equipped with excellent features like compatibility with windows7, count
of all items in individual folder, MS outlook is not required on system for
running application, no need to rescan the file in full version and most
exciting is 100% preview & Detail Summary Report of all recoverable items
which help you to evaluate the software and make better decision about how
helpful will it be for you?
OR
Try n connect to the customer support which help you to go through the
repair process in user friendly manner. I m sure they will help you out to
resolve the problem.
