ClipMate clipboard connection
squire
When Microsoft introduced Outlook 2007 SP2 with its ability to shutdown Outlook gracefully without crashing, the fix that they designed created some sort of conflict with Thornsoft Development's "ClipMate" clipboard extender application that doesn't occur with the SP2 versions of Word and Excel.
Basically, what occurs is that if you use the clipboard in any way while you have Outlook 2007 SP2 open (e.g., copy a phrase out of an open message), that action makes Outllook the new first app in the Clipboard Viewer chain. At such time then as you exit Outlook, instead of the first app in the Clipboard Viewer chain reverting to ClipMate as it does with Word and Excel, the first app in the Clipboard Viewer chain is set to "invalid" thus causing ClipMate to no longer work correctly. (I have contacted Thornsoft Development and they say that there is nothing that they can do with their product to correct for this.)
I am using Windows XP and understand that Vista introduced a new Clipboard API which may make this issue moot. But for those of us who use Outlook 2007 SP2 and Windows XP (SR3), it's really aggravating to have to manually re-establish the connection to the clipboard every time we exit Outlook.
squire
Perhaps, this problem would be completely resolved if Microsoft would change the design of Office 2010 so that the Office Clipboard feature could be completely disabled or removed instead of just hidden.
A Clipboard Resize Issue Using Outlook 7
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
Diane Poremsky Paste clipboard contents using VBA Using Outlook 0
F How can i copy the mail subject and the link to the mail to th clipboard? Outlook VBA and Custom Forms 3
R Outlook 2013 VBA I want to put the entire message to clipboard Using Outlook 5
V Screenshots / Clipboard images disappear after sending Using Outlook 3
M Clipboard Manager Not showing in Outlook 2010 on Start Using Outlook 8
I Clipboard paste in macro Using Outlook 14
K How to copy Contact Item to Clipboard and Paste as "VCF Link? Outlook VBA and Custom Forms 4
e_a_g_l_e_p_i All of a sudden I lost connection to Gmail servers Using Outlook 8
W Encrypted connection to server refused Using Outlook 0
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
M Outlook 2010 Error: Your IMAP server closed the connection Using Outlook.com accounts in Outlook 1
M Outlook Email Connection Error Using Outlook 3
C Last Connection Using Outlook.com accounts in Outlook 1
K Work Email - Calander Connection to Outlook.com Using Outlook 2
R The action cannot be completed. The connection to Microsoft Exchange is unavailable. outlook must be Using Outlook 1
E IMAP server closed the connection Using Outlook 2
P Outlook Connection Issues Using Outlook 3
Z connection to Lotus Notes Using Outlook 4
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
K Intermittent ability to send to single domain. "Connection refused" Exchange Server Administration 1
N Connection Error Using Outlook 2
E intermittent "Your imap server closed the connection" messages Using Outlook 6
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
N Outlooking not connecting. Connection present Using Outlook 1
S Outlook connector, numerous versions, connection issues Using Outlook.com accounts in Outlook 1
S Remote connection to bcm BCM (Business Contact Manager) 1
D Event on connection mode change? Outlook VBA and Custom Forms 2
P Database connection problems BCM (Business Contact Manager) 1
J BCM connection problem BCM (Business Contact Manager) 3
M Outlook 2007 "Connection Status..." shows 3 "Disconnected" entries of type "Directory" Using Outlook 18
T How to establish Soap Connection Outlook VBA and Custom Forms 5
M trouble connection to remote database BCM (Business Contact Manager) 1
M MSO OL sp2 for BCM broke SQL Database connection BCM (Business Contact Manager) 2
