Exchange 2003/2007: how to apply Sender-ID check to HELO/EHLO
P
Pete
Hello.
I am looking for ways to use more thoroughly the SPF/Sender-ID
checking functionality in Exchange (tips for Exchange 2003 and also
2007 are welcome).
In the Linux world, using the "policyd-spf-perl" perl library and
scripts, I know the SPF checks are applied to the MAIL-FROM and the
HELO/EHLO string.
However, in my tests I've only been able to get the Exchange 2003 and
2007 Sender-ID checks to operate on the MIME-FROM address. That is
fine and dandy, but I would like to also apply these checks to at
least the HELO/EHLO string. I do understand that the difference
between SPF and Sender-ID is that the former operates on MAIL-FROM and
the later does on MIME-FROM (a.k.a. "PRA" in Microsoft lingo), but why
can not I use the Exchange Sender-ID check functionality to check the
HELO/EHLO string? Is it perhaps configurable with some registry key?
Am I missing something here?
I know some spammers are connecting to my Exchange server and they are
sending an EHLO string with my domain name. I would like to stop these
connection attempts right there with a SPF/Sender-ID check, but I
cannot find how to do it in Exchange.
Thanks for reading.
-Pete.
Alexander Zammit [MVP]
As far as I know:
1. There is no way to customize the Exchange implementation of Sender ID.
2. MS determines the PRA as specified here:
http://www.ietf.org/rfc/rfc4407.txt
So it is not correct to say that PRA=MIME From header
Alexander Zammit
WinDeveloper Software
IMF Tune - Enable the Exchange 2003 IMF/Exchange 2007 Content Filter to
unleash its full power.
http://www.windeveloper.com/imftune/
"Pete" <usenet@naleco.com> wrote in message
news:2bcea3fa-3a66-4867-a527-6f77dffdc96a@k1g2000yqf.googlegroups.com...
> Hello.
> 2007 are welcome).
> HELO/EHLO string.
> Thanks for reading.
> -Pete.
P
Pete
You are right.
In any case, SPF operates on the email envelope, while Sender-ID
operates in email headers.
So I guess that because at the HELO/EHLO stage the email headers have
not yet been presented to the receiving MTA, the Sender-ID
implementation of Exchange cannot be made to validate the HELO/EHLO
string with the Sender-ID mechanism.
Bummer!
On 23 jul, 23:21, "Alexander Zammit [MVP]" <alex@respond_to_group
wrote:
> As far as I know:
> 2. MS determines the PRA as specified here:http://www.ietf.org/rfc/rfc4407.txt
> > Alexander Zammit
> unleash its full power.http://www.windeveloper.com/imftune/
> "Pete" <use...@naleco.com> wrote in message
> > Hello.
> > 2007 are welcome).
> > HELO/EHLO string.
> > Thanks for reading.
> > -Pete.
Rich Matheisen [MVP]
On Fri, 24 Jul 2009 02:24:26 -0700 (PDT), Pete <usenet@naleco.com
wrote:
> You are right.
IIRC, the E2K7 Edge server does some checking on the data presented in
the HELO\EHLO command.
Rich Matheisen
P
Pepe
That's interesting.
Do you know if that HELO/EHLO checking in Ex2k7 Edge is in any way
configurable? Or what does it check, and whether is it on by default?
> That's interesting.
It's not configurable but, if you're not adverse to dropping a couple
hundred bucks, check out http://www.vamsoft.com.
Put ORF in front of the Exchange stuff (in terms of agent priority,
not necessarily on another server) and you can set up your own set of
criteria for HELO\EHLO, DNSBL, etc. As an added benefit you also get
SURBL scanning and a pretty decent set of reports.
Rich Matheisen
Of course Exchange also provides RBL support @ connection filtering
out-of-the-box
Alexander Zammit
"Rich Matheisen [MVP]" <richnews@rmcons.com.NOSPAM.COM> wrote in message
news:elhs651s4e5j5hkvlag08a8kjpptjio7gu@4ax.com...
>>That's interesting.
> -> Rich Matheisen
On Sat, 15 Aug 2009 13:30:38 +0200, "Alexander Zammit [MVP]"
> out-of-the-box
Neither of which pwemi you to accept or deny email based on the data
portion of the HELO or EHLO commands.
Rich Matheisen
E
Ed Crowley [MVP]
pwemi?
Ed Crowley MVP
"There are seldom good technological solutions to behavioral problems."
news:umud851ndsf6e5j8t3rnd3oicqq54obaio@4ax.com...
> >out-of-the-box
> -> Rich Matheisen
On Sat, 15 Aug 2009 13:39:12 -0700, "Ed Crowley [MVP]"
<curspice@nospam.net> wrote:
> pwemi?
I have no idea what that is! Looks like a short-circuit between my
brain and fingers, doesn't it? "Allows" is what I /think/ I meant to
type, or maybe "permits".
Rich Matheisen
