Reminder not displayed because folder does not support reminders
  • Thread starter Thread starter escamoteur
E
escamoteur
I included the reminder checkbox on my form region. When I create now an iterm in my Folder where I defined my Form as defult and
try saving the item with the checkbox enabled I get the message:
"Reminder will not be displayed, because reminders are nor supported in this folder. Do you agree? Yes/No"
(Translation from the German message)
What do I have to do that my folder supports reminders? I created the folder to hold Taskitems.
I'm using Outlook 2007
Best
Tom
Where is this Tasks folder located? Unlike earlier versions of Outlook,
Outlook 2007 does support reminders in a non-default Tasks folder as long as
it's in your default PST file or Exchange mailbox, or in a non-default PST
file.
About the only place you should see a message like that is in an Exchange
public folders Tasks folder, where reminders are not supported.
"escamoteur" <mail@burkharts.net> wrote in message
news:BF9285FD-D8B8-4206-AACD-BE1E304030A3@microsoft.com...
> Hi,
> iterm in my Folder where I defined my Form as defult and try saving the
> Best
> Tom
Hmm, the folder is in it's own PST-File, not in the default PST.
Best
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:urBItA0HKHA.1492@TK2MSFTNGP03.phx.gbl...
> file.
> > Hi,
>> Best
> > Tom
Do you have Windows Search installed and enabled? Reminders from non-default
folders depend on that. Otherwise I have no idea.
news:DC227795-EE54-4E39-8385-3EE29A3C02B1@microsoft.com...
> Best
> Tom
As I'm using Vista I have Microsoft search automatically, haven't I?
Best
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:O1WGrM3HKHA.4316@TK2MSFTNGP04.phx.gbl...
> > Best
> > Tom
Yes, Vista comes with search.
I added a secondary PST to an Outlook 2007 setup. Then I created a new Tasks
folder in that secondary PST file and set up new a new task with a reminder
in both the default Tasks folder and the new Tasks folder in that PST file.
I got no prompt about reminders and the reminders in both folders showed up
in the To-Do Bar.
Select Tools, Instant Search, Search Options. In that dialog make sure both
your default and secondary PST files are checked under Indexing (Index
messages in these data files). That's the only thing you need set up for
this to work.
news:C77BAD4A-A6A8-4AEE-A212-D8DC86BD399A@microsoft.com...
> Best
> Tom
I know found it. It was not the search, but you gave me a good hint.
I created my PST file from my Add-In. And looking at the property page of the PST file I found that there is a check box that has to
be enabled in order to use reminders in the folder.
Thanks al lot
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:%235NnAPAIKHA.4376@TK2MSFTNGP03.phx.gbl...
> I added a secondary PST to an Outlook 2007 setup. Then I created a new Tasks folder in that secondary PST file and set up new a
> new task with a reminder in both the default Tasks folder and the new Tasks folder in that PST file. I got no prompt about
> reminders and the reminders in both folders showed up in the To-Do Bar.
> Select Tools, Instant Search, Search Options. In that dialog make sure both your default and secondary PST files are checked under
> Indexing (Index messages in these data files). That's the only thing you need set up for this to work.
> "escamoteur" <mail@burkharts.net> wrote in message news:C77BAD4A-A6A8-4AEE-A212-D8DC86BD399A@microsoft.com...
>> Best
> > Tom
Now the question arises: How can I toogle this option at the propertie page of the store that enables remindes from my add-in.
Best
Tom
"escamoteur" <mail@burkharts.net> schrieb im Newsbeitrag news:A263E854-AB58-4986-9CC2-FD0E009D2E7C@microsoft.com...
> to be enabled in order to use reminders in the folder.
> Thanks al lot
> Tom
> " - " <kenslovak@mvps.org> schrieb im Newsbeitrag news:%235NnAPAIKHA.4376@TK2MSFTNGP03.phx.gbl...
> > under Indexing (Index messages in these data files). That's the only thing you need set up for this to work.
>>> Best
> >> Tom
I haven't checked this out, but the setting is probably stored in the
registry somewhere. Run a program such as RegMon to see what gets written
out when you change the setting in the UI.
But for most settings like that Outlook will read the setting on startup but
never again. It writes out any changes but maintains the settings in memory,
so changing a registry setting will only work when Outlook isn't running.
news:7DB03699-D9CF-49F2-87FF-13F8D2DFE32A@microsoft.com...
> Best
> Tom
E Reminder not displayed because folder does not support reminders Outlook VBA and Custom Forms 8
D Outlook 2021 New email reminder Using Outlook.com accounts in Outlook 1
e_a_g_l_e_p_i Is it possible to have a reminder in Outlook 2021 for every 90 days Using Outlook 3
M New Calendar Appointments: Conditionally turn off reminder and show time as free Using Outlook 14
A Reminder duplication Outlook and Outlook.com Using Outlook.com accounts in Outlook 5
V Accepted meetings do not get the default reminder Using Outlook 0
S Command Button_Click action on Item/Reminder Outlook VBA and Custom Forms 3
G Arggh, weakness of reminder for every Task recurrence Using Outlook 0
F how do i set a reminder in onenote 2010 Using Outlook 8
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
A End-time meeting reminder (or "negative" time relative to the meeting start time) Using Outlook 1
M VBA to send reminder email if no response Using Outlook 13
B Change font of reminder of an email header Outlook VBA and Custom Forms 3
O Reminder due end of August is showing up now Using Outlook 2
Witzker Macro to set contact reminder to next day 9:00 Outlook VBA and Custom Forms 45
L Calender reminder emails Using Outlook 3
S Reminder Dialog Open Button Using Outlook 2
F Set (flagged) reminder for next business day Using Outlook 4
H send reminder if no reply received on first or original email using macro Using Outlook 2
Diane Poremsky Open a Webpage When a Task Reminder Fires Using Outlook 0
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
M Messages in Outbox reminder is wrong Using Outlook 4
M Send an Email When a Reminder Fires Outlook VBA and Custom Forms 1
E Send a Reminder/Task to certain Email Recipient Using Outlook 5
Diane Poremsky Send an Email When a Reminder Fires Using Outlook 0
A reminder for every 15 working days Using Outlook 11
Diane Poremsky Setting Custom Reminder Times Using Outlook 0
Diane Poremsky Receive a Reminder When a Message Doesn't Arrive? Using Outlook 10
F e-mail reminder for shared calendar Outlook VBA and Custom Forms 1
K VBA - Prompt for reminder date time Outlook VBA and Custom Forms 7
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
rc4524 Create auto follow-up reminder email for already sent messages Outlook VBA and Custom Forms 1
smokiibear Share Office 365 Tasks such that Other Users also Are Alerted with Reminder Using Outlook 1
J Change reminder times of future appointments Using Outlook 1
S PoP up reminder while opening the outlook? Outlook VBA and Custom Forms 1
S Pop up reminder while i close outlook Outlook VBA and Custom Forms 5
H Create a Task by Draft-EMail > Task+Reminder not Working Outlook VBA and Custom Forms 1
D Outlook 2007- old reminder popups Exchange Server Administration 4
