Inbox is Empty in Outlook 2007 with Cached Mode
David
I recently upgraded to Outlook 2007. When I open it up in Cached
Mode, my inbox is showing up as empty. When I login through OWA,
there are definitely emails in my inbox, so I should be seeing
something. If I open up Outlook with Cached Mode turned off,
everything show sup in my inbox.
This appears to be restricted to my inbox. My Sent Items, Drafts, and
Deleted Item are not effected by this.
Any help would be greatly appreciated.
N
neo [mvp outlook]
Do you have a view set that could be causing this problem? (e.g. start
Outlook with /cleanviews to delete all custom views and reset the built-in
ones back to their defaults.)
Do you have a filter set to not sync items that meet a given criteria? (e.g.
Right click on "Inbox" folder and select properties. Go to the
synchronization tab to review.)
If all else fails, you can delete the .OST file while Outlook is closed.
Next time you start Outlook, a new .OST file will be created and sync'd
against the server.
"David" <davidaharris@gmail.com> wrote in message
news:4e4642f3-2e22-4079-bae7-ba07bfaebc2e@g10g2000yqh.googlegroups.com...
David
Thanks, but I'm still having the same problem. I cleaned the views, I
cleared filters (which there weren't any to begin with) and I deleted
the OST file. My Inbox in Outlook is still empty. Any more ideas?
On Aug 25, 3:23 pm, "neo [mvp outlook]"
> Do you have a filter set to not sync items that meet a given criteria? (e..g.
> against the server.
> "David" <davidahar...@gmail.com> wrote in message
N
neo [mvp outlook]
Any items being posted to the Sync Issues folders?
news:7e82f32f-bdcb-44b9-ae31-4bf8152c2e1d@v2g2000vbb.googlegroups.com...
> (e.g.
> against the server.
David
No, there are not any items in any of the Sync folders.
Everything in my Sent Items, Drafts, and Deleted Items are synched and
work fine. This problem is only limited to my Inbox.
Right now I have Chached mode turned off and everything is working
fine. This is only a short term fix for me as I need to be able to
use Cache mode as I am disconnected from the network quite frequently.
On Aug 27, 4:42 am, "neo [mvp outlook]"
> > (e.g.
> > If all else fails, you can delete the .OST file while Outlook is closed..
> > against the server.
> >news:4e4642f3-2e22-4079-bae7-ba07bfaebc2e@g10g2000yqh.googlegroups.com....
> > Any help would be greatly appreciated.-
N
neo [mvp outlook]
What type of 3rd party things do you have installed that protect, scan, use,
index, sync, fax, .etc Outlook data?
About the only safe thing I have left to suggest is to start Outlook 1 time
with the /resetfolders command line switch.
news:f5abb42a-4420-48fd-a984-30b57f806e22@q14g2000vbi.googlegroups.com...
> > built-in
> > (e.g.
> > against the server.
David
Unfortunately, I'm still having the same problem. I used the /
resetfolders switch with no change. I ran the Office Diagnostics and
it found one problem that it corrected, but it didn't fix this cache
mode issue.
The only 3rd Party plug in is Acrobat PDFMaker 9.0.
Another note, when I look at folder sizes, it shows that my Local Data
Inbox is 0KB and my Server Data Inbox is 423KB. The status bar shows
all folders are up to date. Yet my inbox still shows that there are
no items to view.
I am stumped.
On Aug 27, 5:03 pm, "neo [mvp outlook]"
> > > built-in
> > > (e.g.
> > > against the server.
David
mode issue.
no items to view.
I am stumped.
> > > built-in
> > > (e.g.
> > > against the server.
David
I don't know exactly what was wrong, but I have fixed the problem. I
deleted my Outlook Profile and added a new profile. From that point
on, it has worked fine.
Thanks for all of the ideas.
> mode issue.
> no items to view.
> I am stumped.
> <n...> wrote:
> > What type of 3rd party things do you have installed that protect, scan,use,
> >news:f5abb42a-4420-48fd-a984-30b57f806e22@q14g2000vbi.googlegroups.com....
> > >news:7e82f32f-bdcb-44b9-ae31-4bf8152c2e1d@v2g2000vbb.googlegroups.com....
> > > > built-in
> > > > (e.g.
> > > > against the server.
