All my projects and project tasks are gone - OL BCM 2007
  • Thread starter Thread starter CJ33414
C
CJ33414
I did two things tonight that could have caused this:
1. I went into Communications History within BCM and deleted everything that
was in there
2. I upgraded to SP2
I already deleted the "Deleted Items" from BCM - so if the fix was in there,
it's too late...
Thanks in advance for any help/ideas on how to fix this.
> was in there
> it's too late...
Hi CJ, can you try going into the "Deleted Items" folder under the BCM
tree (in Folders List) and see if you have any of your communication
history items there? If so, drag them back to the BCM Communications
History folder, and they should be back.
I don't think upgrading to SP2 would have caused this... because if it
were the reason, you would have seen an uproar on the forum... :)
Good luck!
John,
I had already deleted all of the items from BCM Deleted Items...it never
even crossed my mind that PROJECTS and PROJECT TASKS would be a communication
history item? Not only because it doesn't seem logical, but because in
quickly looking through the items in there, they all appeard to be emails.
I know I'm "delete happy" - but this is a bit frustrating. I don't know if
I'm mad at myself for not understanding how the program works better, or at
MS - it seems like you have to be so careful, one touch of the wrong button,
everything is gone without so much as a warning "hey, if you delete this,
you're also deleting projects and tasks."
Just doesn't seem logical.
Any other way to recover these items?
CJ
> > was in there
> > it's too late...
> Good luck!
T Business Projects question BCM (Business Contact Manager) 0
E No projects appearing in 'business projects' for bcm Using Outlook 0
J How do you manage "mini-projects?" Using Outlook 4
P Using BCM2010 Business Projects as SharePoint 2007 Data Source BCM (Business Contact Manager) 3
P Company name in Business Projects BCM (Business Contact Manager) 2
S Sharing BCM contacts within Workgroup, Leads and Projects BCM (Business Contact Manager) 5
M linking projects and tasks data to access or excel BCM (Business Contact Manager) 1
C I cannot open business projects but I can view them BCM (Business Contact Manager) 2
C RE: Can I make a template for Projects? BCM (Business Contact Manager) 2
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
Diane Poremsky Project and Business Process Management Tools Using Outlook 0
T link multiple emails to one project in one way BCM (Business Contact Manager) 1
P Autopopulate Email Subject from Project BCM (Business Contact Manager) 6
C Project Management and Communication History BCM (Business Contact Manager) 2
P Simple contact and project manger like MissingLink for Outlook Using Outlook 1
wallisellener Marketing and Project Management field are not displaying BCM (Business Contact Manager) 2
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
T sequential project numbers in Business Contact Manager BCM (Business Contact Manager) 2
M How do I get the version number of the Setup project? Outlook VBA and Custom Forms 1
E trust access to visual basic project greyed out in outlook 2003 Outlook VBA and Custom Forms 1
S O2K vbe error message "Can't find project or library"? Outlook VBA and Custom Forms 3
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
J No setup project with Outlook 2007 Add-In project Outlook VBA and Custom Forms 16
M Adding another add-in to a project Outlook VBA and Custom Forms 1
J Can I link a single project to multiple accounts / business contac BCM (Business Contact Manager) 1
A Re: Convert Oportunity to Project? BCM (Business Contact Manager) 3
J Is the Windows Outlook Tasks module really going to be gone? Using Outlook 10
kburrows Online Archive - Do Not Archive Tasks Using Outlook 1
B Outlook tasks and PDF Using Outlook 4
petunia Outlook tasks module sunsetting? Exchange Server Administration 3
Fozzie Bear Shared Calendar For Scheduled Tasks Using Outlook.com accounts in Outlook 3
R unable to filter tasks when start date is on or before today Using Outlook 4
S Sync Outlook (2021) tasks with Microsoft To Do Using Outlook 1
L Format Lost between Tasks and To Do Using Outlook 0
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
O Tasks - how to display "snoozed" tasks and snooze-times? Using Outlook 7
