navigation pane wishlist
grokit
this is on outlook 2007 connected to exchange.
navigation pane wish #1
switching from shortcuts pane to mailforlders pane while having search results in the list view will reset the search. I'd like to have the search results stay when I change the pane (at least from shortcuts to mail folders, as those are the "same" type of folders.. well, not exactly, but I guess you know what I mean)
navigation pane wish #2
in the vista start menu, I can start typing in the searchbox and the programs and folders shown are reduced to those matching my search string. yeah, nice search feature.
I'd like to see the same behaviour in the navigation pane. that is, I'd like to have a search box there too. while I start typing my string, I would be presented with only the folders of my many pst files, that match the search string. then I should be able to move any message from the list view into one of those found folders.
two nice little features that would make my life easier.
dan
S Navigation Pane Location And Options Using Outlook 19
Diane Poremsky Outlook's Folder Navigation Pane Disappears Using Outlook 2
D Mail accounts don't show up in navigation pane Using Outlook 1
L Navigation Pane selection with shortcuts Using Outlook 2
T Unexpected change of the order of the folders in my navigation pane Using Outlook 6
T Occasionally, no vertical scroll bar in navigation pane in Outlook 2013 Using Outlook 9
K bcm not showing in outlook 2013 navigation pane BCM (Business Contact Manager) 3
D Views with the ToDo Bar and Navigation Pane Using Outlook 1
J How To Change Font Size For Folder Names on Navigation Pane in Outlook 2013 Using Outlook 1
L Navigation Pane Using Outlook 2
N Backing Up Navigation Pane Customizations - WinXP Using Outlook 11
A BCM is not in the navigation line BCM (Business Contact Manager) 2
O Outlook 2013 not holding bottom navigation settings Using Outlook 10
M Calendar navigation displays previous field records.check calendar is shared.. Using Outlook 3
M Add small calendar to navigation Using Outlook 1
C Configuring Navigation shortcuts Using Outlook 3
S Folder Pane Colour Categories Using Outlook 6
bhamberg Shortcuts in Folder Pane (Outlook 2016) Using Outlook 19
B Outlook 365 - Folder pane list clears Using Outlook 28
R Folder pane width change Using Outlook 88
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
GregS What controls content of Folder Pane? Using Outlook 1
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 17
evdbogaard How to dock the Styles Task Pane in the e-mail editing window? Outlook VBA and Custom Forms 1
N Outlook People Pane - Sent Mail Using Outlook 1
W Showing more months in the Calendar nav pane Using Outlook 10
H What Controls what is shown in the preview pane Outlook VBA and Custom Forms 1
