move contents from hundreds of emails into excel
  • Thread starter Thread starter JSpence2003
JSpence2003
I have hundreds of emails that got forwarded from a web form to my email
account. Each email has the same body contents, in that they all have this
basic format below (with different data after each colon). I would like to
try to get a script that can go though this folder, and take the data the
people provided and place it all into Excel rows/columns at one time.
Currently, I copy/paste it into Excel, then I have a macro that takes it from
its current format and moves the data into appropriate fields. This is great,
but can only be done, one email at a time.
Any suggestions?
Add_to_BW_Email_List:
Anniversary_Day:
Anniversary_Month:
BirthdayDay:
Birthday_Month:
address:
city:
email:
name:
state:
submit:
zip:
You can loop through the Items collection of the folder to access each item.
The data is found in the Body property, use the Instr, Left, Right, or Mid
functions to find and extract what you're looking for.
Add a reference to the Excel library to your Outlook VBA project via
Tools/References. Then use the object browser (f2), switch from <All
Libraries> to Excel and see what's available: For instance, Workbooks.Open
opens a workbbok. It has a Sheets collection, and there's a Range object for
working with cells.
Best regards
Michael Bauer
Am Thu, 1 Oct 2009 13:07:04 -0700 schrieb JSpence2003:
from
great,
> Any suggestions?
> Anniversary_Day:
> Anniversary_Month:
> BirthdayDay:
> Birthday_Month:
> address:
> city:
> email:
> name:
> state:
> submit:
> zip:
I have some sample code here you can adapt:
http://www.codeforexcelandoutlook.com/blog/2008/09/export-outlook-contacts-to-excel/
--JP
On Oct 1, 4:07 pm, JSpence2003 <JSpence2...
> Any suggestions?
> Anniversary_Day:
> Anniversary_Month:
> BirthdayDay:
> Birthday_Month:
> address:
> city:
> email:
> name:
> state:
> submit:
> zip:
I have just been tasked with the same request. Were you able to get this to
work?
> Any suggestions?
> Anniversary_Day:
> Anniversary_Month:
> BirthdayDay:
> Birthday_Month:
> address:
> city:
> email:
> name:
> state:
> submit:
> zip:
hi all
just a thought if the body text is divided up by colons you might want to
look at split
BodyArray=split(Myitem.body,":")
this will give you array each element will be the text between the colons
regards
Pete
> work?
> > Any suggestions?
> > Anniversary_Day:
> > Anniversary_Month:
> > BirthdayDay:
> > Birthday_Month:
> > address:
> > city:
> > email:
> > name:
> > state:
> > submit:
> > zip:
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 4
B Outlook 2019 Automatically move email after assigning category Using Outlook 4
M Move command Outlook VBA and Custom Forms 11
B Move emails from one account to another Outlook VBA and Custom Forms 2
Commodore Unable to move message Using Outlook 3
J Dopey move - deleted profile Using Outlook 1
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
M Move to Folder Using Outlook 1
C Can't move folder, the folder is full Using Outlook 0
A Move email items based on a list of email addresses Outlook VBA and Custom Forms 40
T Move calendar invites to new calendar Using Outlook 5
