Outlook has two "screens" -- the Explorer window to show folders and their
contents and the Inspector window to show an individual item. Your
description applies to the Explorer window.
In versions before Outlook 2007, Outlook does not directly expose the
right-click context menu in its CommandBars collection. Richard Kagerer has
posted a code sample at
http://www.outlookcode.com/codedetail.aspx?id=314
that shows how you might trick Outlook into exposing the context menu through
Explorer.CommandBars. The C++ sample add-in at
http://www.codeproject.com/atl/outlook2k3addin.asp also shows a technique for
working with the context menu. Both that and the Kagerer sample, though, use
unsupported techniques.
Outlook 2007 provides Application-level events for the most commonly used
context menus. Eric Legault provides an introduction at
http://blogs.officezealot.com/legault/archive/2007/07/03/20442.aspx
Sue Mosher
"Zdravko" wrote:
> Hi
> I meant on message (there where are From, Subject, Received ...)
> Middle part of a screen if you using preview pane positioned right
> Right of folders ...
> I do not know what is name of that part, but when you right click on
> message,
> there is popup menu:
> Open
> Print
> Reply
> Reply to all
> That popup menu I will override or add some custom entrys, for 2003 and 2007
> version.
> Thank you
> B398BD2EC1BE@microsoft.com...
> > In what Outlook version? Right-click on message where? In a folder view?
> > In
> > the reading pane? In an open Inspector? Please be as specific as possible.
> > > > Sue Mosher
> > > > > > > > "Zdravko" wrote:
> >> Hi
> >> It is possible to override or add cusom actions to rightclick menu (right
> >> click on message) ?
> >> Thank you
> >> Zdravko
