turn Outlook into a Drag-and-drop application
assagai
Goal:
Make outlook 1910 (sorry I meant 2010) fully compatible with drag-and-drop
Problems:
In many cases Drag-and-drop does not work. Here are few examples
1) If a contact is dragged to a “contact filed” of an element (e.g. task) no link is created
2) A graphic file cannot be dropped to a picture area in a contact
3) Partial support for creating a task from a e-mail:
a. A link to a contact is not automatically created for a task
b. If a message was flagged due date in a task still remains unfilled
c. If an e-mail contains attachments there is no option to create an element with original attachments (you can only create an element with the original e-mail as attachment)
I am sure there are much more instances of Drag-and-drop absence
solution:
turn Outlook into a truly Drag-and-drop application
Forum Admin
solution:
On c. You can drag attachment from the open message or the reading pane to the task. It's an extra step, but is easier than always opening the attached email to view the attachment.
The reasoning for not making it easier to add attachments is file size - back when much of the task functionality was completed, mailbox sizes were generally limited and attachments in tasks (and journal) are often forgotten as the cause of 'overquota' messages. Mailboxes are generally larger now and the PST is not restricted to 2 GB, but little has been done to the task feature since the early days.
assagai
that's how I solve the problem now
it's more than 1 extra step:
1) you have to open an e-mail
2) you have to realign task and e-mail windows (alternatively you could use task bar but in my case it's buggy)
3) drag attachments
maybe I am too grouchy but I feel irritated when I have to to do all this extra work, which could've been done in 1 move
I can understand the historical perspective here
however I hope that outlook development team can keep up with the current situation and change their thinking respectively
eliminating of obsolete restrictions is a good way to start
W Outlook Desktop alert, notification, popup - turn off programattic Outlook VBA and Custom Forms 1
R How do I turn off the Business Contact Manager startup in Outlook BCM (Business Contact Manager) 1
H How turn off outlook security warning dialog box from outlook Outlook VBA and Custom Forms 1
T E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
N How to turn off autocorrect in contact notepads Using Outlook 2
A Stop Rule (not turn off) that Delays Outgoing Items Outlook VBA and Custom Forms 1
A Emails automatically forwarding but no rule to turn off Using Outlook 2
K Appointments turn into meeting requests Using Outlook 0
O How to turn off the prompt to permanently delete messages upon exiting? Using Outlook 2
C SQLDUMPER library does not turn on correctly when the computer isturned on each time. BCM (Business Contact Manager) 1
E Turn application visibility off Outlook VBA and Custom Forms 2
V turn off shared calender reminders/leaving personal calender remin Using Outlook 7
G Outlook Express (DBX) to Outlook (PST) Conversion Software Wanted Using Outlook 0
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
P How can I stop Outlook 365 duplicating the posts? Using Outlook 2
