Junk mail filter is junk
assagai
Problems:
I discovered that in Outlook 2010 (unlike previous versions) it is impossible to add certain senders to either safe senders or blocked senders list via context menu.
It is possible to add these very addresses manually (through junk e-mail options dialog window)
I was unable to figure out any reasonable pattern of why some senders get added whilst others don’t
If you use Junk mail filter check from time to time whether address are added as required
solution:
problem has to fixed
Forum Admin
Problems:
solution:
It should work the same as in other versions. (It does here.)
What type of email account do you have configured in Outlook?
D Junk Mail filter Using Outlook 1
D Disable Junk E-mail Filter in Outlook 2007 Using Outlook 13
I Junk Mail and PersonMetadata Using Outlook 2
J Junk mail doesn't work Using Outlook 3
T New Account Shows No Junk Mail Folfer Using Outlook 0
T Probem with junk mail folder in new account in Outlook Using Outlook 0
C Why can junk mail be from one’s own email address? Using Outlook 7
M junk mail folder Using Outlook 2
Diane Poremsky Junk Mail Filtering in Outlook Using Outlook 0
David Rahrer Change default Junk E-Mail folder Using Outlook 6
R Outlook 2007 junk mail Using Outlook 4
C Outlook 2013 Junk Mail Filters Using Outlook 0
Commodore Junk Mail filtering and IMAP Using Outlook 3
A Junk mail Using Outlook 4
U Problems with junk mail folder... Using Outlook 1
G Red crossed circle disappeared from Junk Mail folder Using Outlook 3
O Emails still going to Junk Mail Using Outlook 8
D Junk Mail location Using Outlook 1
E Can rules be applied to the Junk E-mail folder? Using Outlook 2
J Re-enable the junk mail notification. Using Outlook 6
P Setting Hotmail Junk Mail Settings from Outlook Doesn't Work Using Outlook.com accounts in Outlook 1
R How to remove or move the default Junk e-mail folder BCM (Business Contact Manager) 3
N Junk Mail Controls Outlook VBA and Custom Forms 1
T Outlook add-in: How to find localized name of the "Junk e-mail"folder Outlook VBA and Custom Forms 15
J how to stop junk emails from *.onmicrosoft.com ? Using Outlook 2
F Outlook 2016 Junk E-Mails Using Outlook 5
K Emails stuck in 'Junk' folder Using Outlook 0
S Outlook.com - Junk files Using Outlook.com accounts in Outlook 1
R Not junk email Using Outlook 3
lotsbg Loads of junk in second email needs fixing Using Outlook 1
7 Macro to mark message as junk and delete Outlook VBA and Custom Forms 3
G filtering email with missing TLD to Junk Outlook VBA and Custom Forms 1
R Outlook - alternatives to Rules / Junk? Using Outlook 5
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
mrje1 Junk Options - Safe Lists not working. Using Outlook 0
L My junk email folder has disappeared - Using Outlook 0
V Macro to view Junk Email folder Using Outlook 4
J Junk email Exchange Server Administration 1
V Emails going to Junk folder Using Outlook 2
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
