Portable outlook – pst as universal storage
assagai
Portable outlook pst as universal storage
Goal: create a portable unified storage container format for Outlook data and settings
Apparently to some extent this has been implemented in outlook 2007. Recently I had had a major PC crush and restored outlook with the help of backed up pst file.
To my surprise some of the rules and RSS feds reappeared under the new installation. This is a move in the right direction.
In my opinion pst should store all the information related to Outlook:
1) Accounts and send / receive groups. I’ve got a dozen of them with different settings and it’s pain in neck to configure everything from scratch
2) RSS feeds
3) Junk mail filter addresses and domains (both safe and blocked).there were several hundreds of them and it’ll take me a while to configure it again
4) rules
5) Options, settings and personalized ribbon
6) views
there are some security issues (e.g. account passwords) but I would let it for a user to decide.
For instance it’s possible to implement an option NOT to store passwords in the file itself
Forum Admin
Re: Portable outlook pst as universal storage
Views have always been stored in the PST file.
Rules & RSS/internet calendars are, beginning in 2007.
I thought safe and blocked lists are now in the pst too.
assagai
I cannot generalize but when i transfered my pst to new outlook safe and blocked lists were lost completely
half of my RSS feeds were lost too
e-mail Accounts and send / receive groups are definitely not stored in pst
hopefully someone would be able to verify RSS and junk mail issue
Forum Admin
RSS is buggy in Outlook 2007 - the feeds often disappear, so I'm not surprised you lost some when you moved. Are you using the common feed list?
Send and recieve groups are stored in the SRS file. It's in one of the outlook folders under %appdata%. Profiles (accounts) are 100% registry.
assagai
I've noticed that RSS is buggy in Outlook and even consider posting a separate thread on this regard.
I do not use the common feed list and even if I had this would not have helped me: I backed up only my user folder, which contains all the data I need
rules used to be 100% registry too. Hence I welcome the new storage policy and shifting to pst as the primary storage location but I do not understand what the rationale is for stopping half the way.
as a matter of fact, this the point of this thread: move everything into pst
and make sure that whatever items, which are already in PST, work properly
this referres not only to RSS, which were partially lost in my case but also to safe and blocked lists, which had been completely lost for me (probably 1000+ entries or even more)
shivy
not working and i would like to have a portable outlook program to have my pst also portable...
anyone knows where to find a program like this ?
thank you
S Portable MS Outlook or similar using PST Using Outlook 0
J Identifying Portable Devices in Outlook Header Using Outlook 3
A Outlook 2019 folder counter Using Outlook 0
A Relocate Search Bar in Outlook Using Outlook 2
e_a_g_l_e_p_i Need clarification on 2-Step Verification for Gmail using Outlook 2021 Using Outlook 9
L Opening People Outlook 2021 Using Outlook 2
Geldner Problem submitting SPAM using Outlook VBA Form Outlook VBA and Custom Forms 2
P Can no longer sync Outlook with iPhone calendar after iPhone update to 17.1.1 Using Outlook 2
e_a_g_l_e_p_i Is it possible to have a reminder in Outlook 2021 for every 90 days Using Outlook 3
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 3
H Integrating Alexa & Outlook Pro 2021 Using Outlook 2
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
petunia Outlook tasks module sunsetting? Exchange Server Administration 3
D Outlook VBA forward the selected email to the original sender’s email ID (including the email used in TO, CC Field) from the email chain Outlook VBA and Custom Forms 3
U Outlook 2021 not showing contact cards in Searches Using Outlook 1
C Outlook - Macro to block senders domain - Macro Fix Outlook VBA and Custom Forms 2
J Outlook 365 html inline images Using Outlook 0
Rupert Dragwater How to get Outlook 365 to open from websites Using Outlook 5
S Why do I have to close and reopen Outlook for macros to work? Outlook VBA and Custom Forms 2
J Outlook 2021 ScanPST errors (yet again ... sorry): repair button missing Outlook 2021 Using Outlook 0
K Moved pst to new computer, now Gmail not coming into Outlook Using Outlook 7
S Email Macros to go to a SHARED Outlook mailbox Draft folder...NOT my personal Outlook Draft folder Using Outlook 2
F Running Scripts in Outlook 2021 Using Outlook 0
Nufc1980 Outlook "Please treat this as private label" auto added to some emails - Help. Using Outlook 3
V Outlook macros no longer run until VB editor is opened Outlook VBA and Custom Forms 0
R Outlook 365 How to integrate a third-party app with Outlook to track email and sms? Using Outlook 2
e_a_g_l_e_p_i I can't believe what I am seeing when trying to install Outlook 2021 Using Outlook 9
P How to get a QR code for automatic signin with Outlook for iOS Using Outlook 5
J Migrating Outlook Using Outlook 1
Retired Geek Outlook for the MAC with Yahoo accounts now very broken Using Outlook 9
L How Stop Outlook Nag Messages Using Outlook 1
L I Cannot Sign Into My Outlook Account? Outlook VBA and Custom Forms 0
icacream Outlook 2021 - Google calendar in the peek Using Outlook 0
e_a_g_l_e_p_i Question about installing my Gmail account on my iPhone but still getting messages downloaded to my desktop Outlook. Using Outlook 3
