[O2007] -> How to search for a string in the body and get the line number?
  • Thread starter Thread starter Steve JORDI
Steve JORDI
I'm trying to get a reply to a mail message and look for a specific
substring.
Then I need to know the position of the line.
For example:
search "Sincerely yours,"
get the line number
insert 3 lines BEFORE the "Sincerly Yours"
I can't find a way. I know how to use Replace to change
subtrings, but I can't get a way to just locate one and get
the line number.
How can I do this?
Then, how can I insert text at that linePosition-3?
Thanks for any help.
Sincerely,
Steve JORDI
(Remove the K_I_L_LSPAM from my email address)
----------------1197 Prangins Email: stevejordiK_I_L_LSPAM@hotmail.com
Switzerland WWW: www.sjordi.com
----------------Volcanoes at www.sjordi.com/volcanoes
MovieDB at www.sjmoviedb.com
RE: [O2007] -> How to search for a string in the body and get the line
Steve-
There may be a better way, but here is some code that might help. This code
takes an email and splits lines into an array. You could then loop from
lbound(arrayname) to ubound(arrayname) and use Instr to find the line with
your target string.
At that point, you would know from the loop what (line) number the string
was found on, and be able to go back to the source message and replace the
line n-3 with x = y & vbcrlf & x
where x is the original line, and you are inserting your target text
followed by the line that was already there.
For the following code, you can just ignore all the Excel stuff, and just
focus on the split statement and array.
Sub ParseEmailFolderToExcel()
Set objApp = Application
Set olns = Outlook.GetNamespace("MAPI")
Set myinbox = olns.PickFolder
'Set myItems = myinbox.Items
Dim XLApp As Excel.Application
Dim wkb As Excel.Workbook
Dim wks As Excel.Worksheet
Dim ExcelWasNotRunning As Boolean
Set XLApp = GetObject(, "Excel.Application")
If Err Then
ExcelWasNotRunning = True
Set XLApp = New Excel.Application
XLApp.Visible = True
Set wkb = XLApp.Workbooks.Add
Set wks = wkb.Sheets(1)
With wks
StartCount = 0
strEmailContents = ""
For Each outlookmessage In myinbox.Items
StartCount = StartCount + 1
> Range("A" & StartCount).Value = outlookmessage.ReceivedTime
> Range("B" & StartCount).Value = outlookmessage.SenderName
> Range("C" & StartCount).Value = outlookmessage.Subject
FullMsg = outlookmessage.Body
AllLines = Split(FullMsg, vbCrLf)
eachval = Split(AllLines(2), """,""") 'I was just grabbing the
second line
> Range("D" & StartCount).Value = Right(eachval(0),
Len(eachval(0)) - 1)
> Range("E" & StartCount).Value = eachval(1)
> Range("F" & StartCount).Value = eachval(2)
> Range("G" & StartCount).Value = eachval(3)
> Range("H" & StartCount).Value = eachval(4)
> Range("I" & StartCount).Value = Left(eachval(5),
Len(eachval(5)) - 2)
On Error GoTo 0
'you'd need to use something like:
For eVal = lbound(eachVal) to ubound(eachval)
'the ucase and all caps are to find a match without being
case sensitive
'if you eliminate the ucase and try to match "Sincerely
Yours" then
'it would not find the line "Sincerely yours" for example.
FoundString = Instr(UCASE(eachVal(eVal)),"SINCERELY YOURS,")
If(Not(IsERROR(FoundString))) then
'Do your replacement code on line eVal-3 (or would that
be eVal -2?)
Set myOlApp = Nothing
Set olns = Nothing
Set myinbox = Nothing
Set myItems = Nothing
"Steve JORDI" wrote:
> Hi,
> substring.
> For example:
> get the line number
> the line number.
> How can I do this?
> Sincerely,
> Steve JORDI
> ----------------------------------------------> 1197 Prangins Email: stevejordiK_I_L_LSPAM@hotmail.com
> ----------------------------------------------> Volcanoes at www.sjordi.com/volcanoes
S ->[O2007] Any way to know the Plain Text Wrap limit? Outlook VBA and Custom Forms 2
S ->[O2007] Parsing each line of a MailItem HTMLBody? Outlook VBA and Custom Forms 2
S -> [O2007]: get the message HTML original source code? Outlook VBA and Custom Forms 6
A people search returns 'email properties' for one contact Using Outlook 26
V How to disable Server Assisted Search Using Outlook 2
C Search bar moved on its own? Using Outlook 4
A Search People>press enter box disappears. Using Outlook 3
efire9207 Addressbook Search Using Outlook 4
Victor_50 Outlook 365 Quick search by period (today, yesterday, last week) completely missing in newest OL 365 Using Outlook 0
A 'search people' now asks me to 'press enter' Using Outlook 11
A Relocate Search Bar in Outlook Using Outlook 2
T Outlook365 search item listed as "potential matches" can't be opened Using Outlook 0
P Outlook 2013 search no longer works Using Outlook 2
C How to search for items in Outbox with multiple accounts? Using Outlook 20
J search doesn't find anything Using Outlook 1
C Search not accurate, but not indexing Using Outlook 9
H Outlook 2019 intermittent search results Using Outlook 0
H Search Email Header for Content Type Outlook VBA and Custom Forms 1
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
O Advanced search - can I use booleans Using Outlook 3
M Something went wrong and your search couldn't be completed Using Outlook 1
