Need help resetting email default setting on Outlook 2003
  • Thread starter marthabw99
  • Start date Views 760
marthabw99
I set up my email so that the message was underlined and accidentally clicked
on "default". Since then all my emails go out with the message completely
underlined ... even though I don't see that until I go and look in the "send"
folder. I have made sure all the settings in the email options do not have
the underlining ... but it still does it! I also actually reconfigured
outlook completely and it still maintained that setting. Help!!!
Brian Tillman
Are you using Outlook's built-in editor or are you using Word to compose your messages?
