click on contact behaviour
assagai
introduction of contact cards made access to information more difficult
most of my tasks are linked to contacts.
in previous versions of Outlook a double click on contact name used to evoked a card (from contacts folder)
in new version it evokes a "contact card" rather then regular contact
I personally don't see any advantages of a "contact card" over a regular contact
you cannot start a phone call from a contact card unless your are subscribed to MS IM (no side software vendors support this feature)
the information reflected in a "contact card" is limited compared to a regular contact
if someone likes it - it's OK though. just give users a choice.
for example a single click could evoke a contact card whereas a double-click a regular contact
that would suffice to resolve the problem
alternatively make an option prescribing application's behaviour with linked contacts
Oooo
There is ability to switch to legacy view. At least in OL2010.
M right click contact to create an appointment Using Outlook 4
R One Click business contact record creation - From an E Mail? BCM (Business Contact Manager) 1
P Contact Manger locks up Outlook when I click on folder? BCM (Business Contact Manager) 2
S mouse right click options Using Outlook 2
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
B Open a folder / subfolder of a PST in single click Outlook VBA and Custom Forms 4
Diane Poremsky Contacts are missing when you click the To button Using Outlook 0
M Office 365 Click to run BCM (Business Contact Manager) 0
F Jump to Inbox folder when click on Favorite Using Outlook 0
I BCM Opportunity: click on "new op" opens a "new tasks" BCM (Business Contact Manager) 0
M Automatically move Outlook message to the specific folder when click on reply to all Using Outlook 4
M Blank Pop-up Window when click "Manage Sharing" BCM (Business Contact Manager) 1
L Add to Right Click Menu Using Outlook 10
T Is the standalone Outlook 2013 click-to-run or msi? Using Outlook 1
A Uninstall Click and Run Exchange Server Administration 2
B Right click-drag no longer creates hyperlinks Using Outlook 2
A email folders appear empty, at first click Using Outlook 2
L Outlook 2010 Instant Search Pops When I Click Using Outlook 6
T Click "A" to see all email from people with names starting with A... etc Using Outlook 3
V Can't click on embedded link in Outlook e-mails--error message "not allowed" Using Outlook 6
T drag drop/opening drop down/single click acts like double/highlighting Using Outlook 7
F When I click on link in email nothing occurs Using Outlook 7
M Programatically click the Send button. Outlook VBA and Custom Forms 5
K call a help file when click on a button xml ribbon Outlook VBA and Custom Forms 1
M auto click hyperlink?! Outlook VBA and Custom Forms 1
M Auto click a hyperlink Outlook VBA and Custom Forms 2
H Program "Click on Ribbon Button" Using VBA Outlook VBA and Custom Forms 1
J Macro to open email (like double click) in Outlook Outlook VBA and Custom Forms 4
M How to provide custom functionality on click of "New"? Outlook VBA and Custom Forms 1
M How to resize the instant search pane on click on the icon to expand/ Outlook VBA and Custom Forms 1
Z Right click menu Outlook VBA and Custom Forms 4
N Right-click an address -> add to BCM? [OL2007] BCM (Business Contact Manager) 1
V List Click Outlook VBA and Custom Forms 1
U Adding multiple menu Items. Problems handling the click events Outlook VBA and Custom Forms 1
