users can delete public folder calendar entries without permission
  • Thread starter shrpshtr
  • Start date Views 1,771
shrpshtr
why would a user be able to delete a calender entry in exchange 2003
(Active Directory) public folder with permissions on that folder set
to none in the delete section? any help would be greatly appreciated.
shrp
Rich Matheisen [MVP]
On Mon, 15 Mar 2010 17:23:15 -0700 (PDT), shrpshtr
The short answer is that they wouldn't be able to do that.
Rich Matheisen
L
Leonid S. Knyshov // SBS Expert
> shrp
Deny permissions override Allow. Both permissions can be inherited.
If there is Allow permission upstream and you don't have a corresponding
Deny setting, then the Allowed user can delete.
Leonid S. Knyshov
Try Exchange Online http://bit.ly/free-exchange-trial
shrpshtr
Re: users can delete public folder calendar entries withoutpermission
On Mar 16, 3:19 am, "Leonid S. Knyshov // SBS Expert"
<LeonidSKnyshovSBSExp...> wrote:
> On 3/15/2010 5:23 PM, shrpshtr wrote:> why would a user be able to deletea calender entry in exchange 2003
> > to none in the delete section?  any help would be greatly appreciated..
> > shrp
> > Leonid S. Knyshov
> http://crashproofsolutions.com
> Try Exchange Onlinehttp://bit.ly/free-exchange-trial
I've looked under ESM and can't find anywhere that permissions are
allowing this to occur. Is there anywhere else I need to check?
To Rich - I know they "won't" be able to do this but they can, and are.
Re: users can delete public folder calendar entries without permission
On Tue, 16 Mar 2010 06:30:09 -0700 (PDT), shrpshtr
> > On 3/15/2010 5:23 PM, shrpshtr wrote:> why would a user be able to delete a calender entry in exchange 2003
> > > shrp
[ snip ]
Then the permissions aren't what you say they are.
Try using PFDAVADMIN and reset the permissions order.
MAPI arranges ACEs in the ACL in an order different to those in NTFS.
MAPI permissions are "deny,allow,deny,allow,deny,allow,. . . ", NTFS
are "deny,deny,deny,allow,allow,allow,..."
You don't offer much in the way of details as to the arrangement of
the permissions. Are the permissions given to a group or to an
individual? Are the individuals members of groups that have been given
perissions? Are groups members of other groups that have been given
permissions?
In the "look but don't touch" category, hold down the Control key and
click the "Client permissions..." button on the folder. Perhaps the
more familiar "NTFS view" will help find the cause.
Rich Matheisen
