How do I run a rule by using a toolbar icon?
  • Thread starter Thread starter DLGolfs
DLGolfs
I have Outlook 2007 and have a rule set up to delte spam by detecting certain
words in the spam.
Here is what someone gave me but it does not work:
Sub RunRuleDeleteSpam()
Dim oNS As Outlook.NameSpace
Dim oStore As Outlook.Store
Dim colRules As Outlook.Rules
Dim oRule as Outlook.Rule
Set oNS = Application.GetNameSpace("MAPI")
Set oStore = oNS.DefaultStore
Set colRules = oStore.Rules
Set oRule = colRules.Item("Delete Spam")
oRule.Execute
If I run it it highlights the set oRule line and stops, I guess. I know
nothing about programming, I'll admit, but am not ignorant on computer
processes. I thought if I could make a macro to run a rule then I could put
the macro in a toolbar icon and just click on it instead of having to go
through a series of clicks.
What do you think? Is the formula wrong or what?
What does the error message say? I guess the rule "Delete Spam" doesn't
exist.
Best regards
Michael Bauer
Am Thu, 18 Mar 2010 17:48:01 -0700 schrieb DLGolfs:
certain
> words in the spam.
> oRule.Execute
> End Sub
put
No error just highlights the the line
Yes, the rul Delete Spam does exisit, I can run it manually all the time.
I tried to export the rules and put the file here but it did not work.
I have the rule name Delete Spam
> exist.
> > Best regards
> Michael Bauer
> certain
> > words in the spam.
> > oRule.Execute
> > End Sub
> put
No error just highlights the line as I stated below. That is it.
Yes, the rule Delete Spam does exisit, I can run it manually all the time.
> exist.
> > Best regards
> Michael Bauer
> certain
> > words in the spam.
> > oRule.Execute
> > End Sub
> put
if you modify the code to this:
MsgBox Err.Description
what does the prompt tell you?
Best regards
Michael Bauer
Am Sat, 20 Mar 2010 03:23:01 -0700 schrieb DLGolfs:
> > exist.
>> > > Best regards
> > Michael Bauer
> > certain
> >> words in the spam.
> >> oRule.Execute
> >> End Sub
> > put
go
Gary Brown Outlook 2013 VBA to run a rule Outlook VBA and Custom Forms 13
J outlook rule doesn't run automatically Using Outlook 0
O Run Rule to Rename Email and Add to Tasks Using Outlook 4
D Create a macro in Outlook to run a rule Outlook VBA and Custom Forms 32
L Run script rule not exectued for first few mails Outlook VBA and Custom Forms 2
J Outlook, Word, Access crash unless run in Admin mode - time dependent it seems Using Outlook 10
V Outlook macros no longer run until VB editor is opened Outlook VBA and Custom Forms 0
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
B run scripts Using Outlook 1
P errors appear every time I run SCANPST Using Outlook 3
J VBA Run When Reply Outlook VBA and Custom Forms 4
