Outbox not responding
  • Thread starter Thread starter Rose B
Rose B
I have a MS Access application which uses VB to construct/send emails.
The application is used by some users with Office 2007 and some using Office
2003.
The Office 2007 users have "ClickYes" software from ContextMagic installed.
The MS Access application is distributed as 2007 runtime.
What I have found is that all is well for Office 2007 users all of the time,
and for Office 2003 users if Outlook is closed when the email is sent
(ClickYes accepting the security alert boxes). However, if a Office 2003 user
has Outlook open (which is normal) when the .Send command is issued from VB
then they will see a box stating that the "action cannot be completed becuase
the Outbox - Microsoft Outlook application (Outbox - Microsoft Outlook) is
not responding. Cjoose Switch To to activate Outbox...........". The user can
then click one of two buttons - Switch To... or Retry. Whichever they click
dies the trick and the application continues OK.
Does anyone know of any way of stopping this box from appearing and the
processing continuing without user intervention?
(I will post this in the Access Programming forum as well).
For me it sounds like you should ask the ClickYes people.
Best regards
Michael Bauer
Am Tue, 30 Mar 2010 15:42:01 -0700 schrieb Rose B:
Office
> 2003.
installed.
time,
user
VB
becuase
can
click
Yeah, I did that - and they said that their product could not code around
this message. The strange thing is that if you use Mail Merge to generate
Outlook messages from Access, this message does not appear (and of course the
security messages are handled OK by ClickYes), so I thought that there must
be some kind of flag that is being set by Mail Merge and that I am missing in
my VB statement.
> > Best regards
> Michael Bauer
> Category Manager -
> SAM - The Sending Account Manager:
> Office
> > 2003.
> installed.
> time,
> user
> VB
> becuase
> > not responding. Choose Switch To to activate Outbox...........". The user
> can
> click
It's not a flag. It's a message created using Simple MAPI that is causing
the problems. You're probably using DoCmd to send the mail? You would need
to start Outlook using automation code and use the Outlook object model to
avoid the problem and to have ClickYes work correctly.
"Rose B" <RoseB> wrote in message
news:C561F798-4CC4-474C-A941-8697DF3C91F0@microsoft.com...
> the
> must
> in
> my VB statement.
The code that I am using follows..... which I think is the kind of thing that
you are suggesting?
Dim appOutlook As Object
Dim appOutlookMsg As Object
Dim appOutlookRecip As Object
Set appOutlook = CreateObject("Outlook.Application")
Set appOutlookMsg = appOutlook.CreateItem(olMailItem)
strRecipient = "rose.b@tiscali.co.uk"
With appOutlookMsg
Set appOutlookRecip = .Recipients.Add(strRecipient)
appOutlookRecip.Type = olTo
> Importance = 2
> Subject = "Test Msg"
> Body = "Dear You, this is a test message from Access 2007"
> Send
> > the
> > must
> > in
> > my VB statement.
That is Outlook automation, not Simple MAPI, so it is what I was talking
about. I'm really surprised that ClickYes can't handle that.
You might want to try using GetObject() to see if you can pick up an
existing Outlook session before you use CreateObject(), perhaps ClickYes can
handle that.
I don't use ClickYes, nor do most Outlook developers. I consider it a
security risk, and we have Redemption (www.dimastr.com/redemption) to avoid
the security and provide a whole heck of a lot more functionality than
ClickYes.
news:4B0F4050-7D4D-4F1A-8E81-4E64250EC452@microsoft.com...
> that
> you are suggesting?
> With appOutlookMsg
> .Importance = 2
> .Subject = "Test Msg"
> .Body = "Dear You, this is a test message from Access 2007"
> .Send
> End With
Thanks Ken.... I solved it!!! (And a real Doh! moment it was too). Somehow
the OLE Automation library had been dropped. Once I put that into the
References all was OK.
I had looked at Redemption before, but the folk I have been doing this for a
re a charity and there are only a couple of users so they didn't really want
to be buying software. I have also looked today at MAPILab's Advanced Outlook
Security, which looks much more rich in functionality. At least with ClickYes
whether it is Active or not can be controlled through VB so it won't just
click through all the time.
Anyway, all's well - thanks for your time.
> handle that.
> ClickYes.
> > that
> > you are suggesting?
> > With appOutlookMsg
> > .Importance = 2
> > .Send
> > End With
If you do more Outlook projects, Redemption for sure will pay off. There'd
be no need to have one customer pay for the entire cost.
Best regards
Michael Bauer
Am Wed, 31 Mar 2010 09:44:01 -0700 schrieb Rose B:
a
want
Outlook
ClickYes
can
> > handle that.
avoid
> > ClickYes.
> >> that
> >> you are suggesting?
>>> With appOutlookMsg
> >> .Importance = 2
2007"
> >> .Send
> >> End With
M Why oft-file opens as outbox not as draft Outlook VBA and Custom Forms 4
Horsepower Cannot delete gmail in iPhone Outlook outbox Using Outlook 1
C How to search for items in Outbox with multiple accounts? Using Outlook 20
B One email cannot be sent or received (but leaves outbox!) Using Outlook 1
A Cant See outbox items on a secondary Account Exchange Server Administration 3
M Outbox throttler Using Outlook 4
T SMTP messages stuck in Outbox Using Outlook 0
I Outlook 2013 Send mail - it just sticks in Outbox Using Outlook.com accounts in Outlook 0
Diane Poremsky After viewing the Outbox, messages won't send Using Outlook 0
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
M Messages in Outbox reminder is wrong Using Outlook 4
D Use single outbox in Outlook 2013 Using Outlook 1
T Two Outbox's in 2007 but neither send Using Outlook 8
iwshim Transfering mail from the outbox to another computer Using Outlook 0
G "Delay Delivery" Email fails to send if opened while in Outbox Using Outlook 4
F Outbox - Multiple Emails need to be manually opened? Using Outlook 5
B OUTBOX ERROR!!!!! Using Outlook 20
James Emails Stuck In Outlook Outbox Happening Alot Using Outlook 1
Loperman Emails hang in Outbox Using Outlook 1
M some emails send from outbox, some don't Using Outlook 10
S Mystery emails in Outbox Using Outlook 1
J Change Subject of 500 mails sitting in Outbox with Macro Using Outlook 6
B Cannot send emails-stuck in OutBox: OUTLOOK 2013 Using Outlook 4
E lost contacts on emptying outbox? Using Outlook 5
N Stuck in Outlook 10 Outbox Using Outlook 0
M Messages Held in Outbox 2007 Outlook 2010 Using Outlook 1
K blank emails generated in outbox when clicking on Inbox and other foders Using Outlook 0
R Force use of general outbox Using Outlook 1
J Emails stuck in Outlook outbox Using Outlook 11
P OL 2007 XP email stuck in outbox Using Outlook 3
D Email stuck in Outbox Using Outlook 3
X Exchange 2013 - Emails stuck in Outbox folder Exchange Server Administration 3
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
D Outbox will not send, error code 0X800CCC78 with 550 sender restricted. Using Outlook 3
G Email stuck in Outbox - Office 2013 Using Outlook 5
N Email Stuck in Outbox - Cached Mode - Roaming Profile Using Outlook 2
D Windows 7 / Outlook 2007 - email gets stuck in Outbox Using Outlook 2
A Mail Merge - Sent but still in Outbox Using Outlook 5
T Sent emails remain in Outbox Using Outlook 3
P Messages stuck in outbox and must be sent again. Using Outlook 1
