MailItem.SaveAs not working
C
Chris
I am trying to save messages as a MSG format. I checked on the forum and
found the code but when I save, the file name is not completely written and
the file size is 0 bytes. Right now the code is only for the open message.
Ideally, I would like the code to be run on an Outlook folder. I am
operating in a Vista Enterprise environment. Any help would be greatly
appreciated.
-----VBA Code---
Sub SaveAsTXT()
Dim myItem As Outlook.Inspector
Dim objItem As Object
Dim strname As String
Set myItem = Application.ActiveInspector
If Not TypeName(myItem) = "Nothing" Then
Set objItem = myItem.CurrentItem
strname = "U:\E-Mail\" & objItem.SenderName & " " & objItem.Subject
& objItem.Sent & ".msg"
MsgBox strname
'Prompt the user for confirmation
Dim strPrompt As String
strPrompt = "Are you sure you want to save the item? " & _
"If a file with the same name already exists, " & _
"it will be overwritten with this copy of the file."
If MsgBox(strPrompt, vbYesNo + vbQuestion) = vbYes Then
objItem.SaveAs strname, olMSGUnicode
MsgBox "There is no current active inspector."
-----End of VBA Code-----
K
Ken Slovak - [MVP - Outlook]
See if the file name you end up with has any illegal characters in it. See
if you can save the same item yourself manually, to see if that works.
"Chris" <Chris> wrote in message
news:C7994A49-C95B-4D0F-BF02-A2AEB97EBA13@microsoft.com...
> and
> message.
> appreciated.
> -----VBA Code---> Sub SaveAsTXT()
> MsgBox strname
> End If
> Else
> End If
> End Sub
C
Chris
Ken,
That partially solved the problem as it was adding an additional path to the
name which had illegal characters. However, it seems to be missing items
such as read receipts, meeting requests and responses, and tasks. Is there a
way to check for these items and then make the filename based on those
available fields? My thought is to do a Select Case TheEmail.Class but I
don't know if this will work and what fields are availble to create a name.
Right now, messages are created by SenderName, a scrubbed subject, and a
scrubbed received date. I would assume that I have to scrub any of the
fields in the other item types.
Thanks for assisting.
> > and
> > message.
> > appreciated.
> > -----VBA Code---> > Sub SaveAsTXT()
> > MsgBox strname
> > End If
> > Else
> > End If
> > End Sub
K
Many of those "missing things" would not be available in a saved out MSG
file. You can certainly get any fields you want from a mail item to provide
a naming scheme, but in all cases you will want to make sure there are no
illegal characters in the resulting file name. These days you don't need to
worry about things like making your file name an 8.3 format, but illegal
characters are always a concern.
news:98EAE2C1-34A6-4753-882E-CEED4F7E0246@microsoft.com...
> Ken,
> the
> there a
> name.
C
Chris
Ken,
Is there a way to save the delivery and read receipts and meeting request
acceptances/declines?
I looked at the Class of the delivery receipt and it came up the same as a
message. There is no ol equivalent for a read or delivery receipt but there
is for meeting requests.
I need to be able to copy everything in a folder to a .msg format. My code
works on messages perfectly but not on those items mentioned. I did scrub
the information and it still would not save. PLEASE HELP!!!!!
Chris
> > Ken,
> > the
> > there a
> > name.
K
I'm not sure what you're talking about.
Delivery reports for example have a MessageClass of "REPORT.IPM.Note.DR".
That's not an email MessageClass.
You would instantiate any item where the MessageClass starts with "REPORT"
as a ReportItem, with which you should be able to use SaveAs().
Most recipients won't allow delivery of either types of reports, but where
you do get them back that's what you'd do.
news:CB8A7BEA-8D3F-4E0B-972C-A746527770DC@microsoft.com...
> Ken,
> there
> code
> Chris
C
Chris
Ken,
The Class I was referring to is the
Application.ActiveExplorer.CurrentFolder.Items.Item(I).Class. I had a return
of 43.
I do not know how to utilize MessageClass to isolate as it seems to call the
delivery receipt IPM.NOTE according to what was outputted to the messagebox
and not as what you had below. I am using Outlook 2007.
Chris
> > Ken,
> > there
> > code
> > Chris
K
You need to check the item's MessageClass property, which is a string. If
you are doing that in a procedure or event handler where the item is an
Object you would do that using reflection.
If you use Class, which won't work for you correctly, you will need to try a
cast to MailItem, if that fails try a cast to ReportItem and so on.
Personally I'd be using MessageClass myself.
I'd get MessageClass and use string.StartsWith() to see if the MessageClass
starts with "REPORT".
news:01F22F06-F7A2-4A64-849A-D68D6EF7F6A6@microsoft.com...
> Ken,
> return
> of 43.
> the
> messagebox
> Chris
C
Chris
OK Ken,
It seems so close and yet so far away. I am doing the message class but
anytime it htis a delivery report or read receipt, I cannot get the message
class. I have a check to add the category "Not Copied" (it exists in the
list) and it will change the category of the message prior to the receipt.
The message box never displays a "REPORT" message class just "IPM.NOTE" and
the out of office one. I am including the code and am hoping a light will
shine on the error in the code. Thanks for your continued assistance.
Chris
-----CODE START---
Dim TheEmail As Outlook.MailItem
Dim eItem As Outlook.Items
Dim EmailNS As NameSpace
Dim fldrCount, EmailPath2, NbrItem, myfolder
Dim strSubj, strTime, mailClassCheck, EmailPath As String
Dim NewFileName As String
Dim Cats
Dim CheckErr, Exists As Boolean
CheckErr = False
Set EmailNS = Application.GetNamespace("MAPI")
Set myfolder = Application.ActiveExplorer.CurrentFolder
NbrItem = myfolder.Items.Count
On Error GoTo Error_Handler
'EmailPath = InputBox("Enter the save folder location:", "Email Save
Path", CurDir)
EmailPath = "C:\users\CMPurdom\Desktop\Mail Burn\Tester\"
For i = 1 To NbrItem
Set TheEmail = Application.ActiveExplorer.CurrentFolder.Items.Item(i)
mailClassCheck = TheEmail.MessageClass
MsgBox mailClassCheck
If Right(mailClassCheck, 6) = "REPORT" Then
SaveMailAsFile TheEmail, olSaveAsMsg,
"C:\users\CMPurdom\Desktop\Mail Burn\Testers\"
GoTo Step1
If TheEmail.Subject = "" Then strSubj = "no subject"
strSubj = Replace(TheEmail.Subject, "/", "-")
strSubj = Replace(strSubj, "\", "-")
strSubj = Replace(strSubj, ":", "--")
strSubj = Replace(strSubj, "?", sReplace)
strSubj = Replace(strSubj, Chr(34), sReplace)
strSubj = Replace(strSubj, "<", sReplace)
strSubj = Replace(strSubj, ">", sReplace)
strSubj = Replace(strSubj, "|", sReplace)
strTime = Replace(TheEmail.ReceivedTime, "/", "-")
strTime = Replace(strTime, "\", "-")
strTime = Replace(strTime, ":", ".")
strTime = Replace(strTime, "?", sReplace)
strTime = Replace(strTime, Chr(34), sReplace)
strTime = Replace(strTime, "<", sReplace)
strTime = Replace(strTime, ">", sReplace)
strTime = Replace(strTime, "|", sReplace)
'SaveMailAsFile TheEmail, olSaveAsMsg, "C:\users\CMPurdom\Desktop\Mail
Burn\Testers\"
NewFileName = TheEmail.SenderName & "_" & strTime & "_" & strSubj &
".msg"
If NewFileName <> "" Then
TheEmail.SaveAs EmailPath & NewFileName, olMSG
MsgBox "No file name was entered. Operation aborted.", 64,
"Cancel Operation"
Step1:
Next i
GoTo Done
Error_Handler:
MsgBox TheEmail.MessageClass & Chr$(13) & TheEmail.Subject & Chr$(13) &
Err.Number & ": " & Err.Description
TheEmail.Categories = TheEmail.Categories & ";" & "Not Copied"
TheEmail.Save
Resume Next
Done:
> > Ken,
> > return
> > of 43.
> > the
> > messagebox
> > Chris
K
I'm wondering if possibly declaring TheEmail as Object rather than MailItem
would be helpful. Do you ever hit the error handler code? If you do it
could be because instantiating a MailItem object from a report item would
fire an exception.
news:7E7B26D3-E491-4C8D-AFB3-C6C437C09A15@microsoft.com...
> OK Ken,
> message
> and
> Chris
> -----CODE START---> Dim TheEmail As Outlook.MailItem
> Dim Cats
> CheckErr = False
> Path", CurDir)
> GoTo Step1
> End If
> Burn\Testers\"
> ".msg"
> Else
> "Cancel Operation"
> Exit Sub
> End If
> Step1:
> Next i
> GoTo Done
> Error_Handler:
> TheEmail.Save
> Resume Next
> Done:
> End Sub
> -----CODE END-----
C
Chris
Ken:
Declaring it as an object worked. I am including the code below which also
includes a browser supported function in case anyone has the same problem
they can find it. Thank you for your help.
Chris
'-----CODE START---
Public Sub ExportSAR()
Dim TheEmail As Object
Dim ReportEmail As ReportItem
Dim NewFileName, ReportHeader As String
Dim Cats
CheckErr = False
EmailPath = BrowseForFolderShell
MsgBox EmailPath
Path", CurDir)
If Left(mailClassCheck, 6) = "REPORT" Then
Set ReportEmail =
If ReportEmail.Subject = "" Then strSubj = "no subject"
If Right(ReportEmail.MessageClass, 2) = "DR" Then ReportHeader =
"DeliveryReport" Else ReportHeader = "Read Receipt"
strSubj = Replace(ReportEmail.Subject, "/", "-")
strTime = Replace(ReportEmail.CreationTime, "/", "-")
NewFileName = ReportHeader & "_" & strSubj & strTime & ".msg"
ReportEmail.SaveAs EmailPath & NewFileName, olMSG
"Cancel Operation"
GoTo Step1
".msg"
"Cancel Operation"
Step1:
strSubj = ""
strTime = ""
Next i
GoTo Done
Error_Handler:
If TheEmail Is Nothing Then
MsgBox Err.Number & ":" & Err.Description Else
TheEmail.Save
Resume Next
Done:
Public Function BrowseForFolderShell(Optional Hwnd As Long = 0, Optional
sTitle As String = "Browse for Folder", Optional BIF_Options As Integer,
Optional vRootFolder As Variant) As String
Dim objShell As Object
Dim objFolder As Variant
Dim strFolderFullPath As String
Set objShell = CreateObject("Shell.Application") Set objFolder =
objShell.BrowseForFolder(Hwnd, sTitle, BIF_Options, vRootFolder)
If (Not objFolder Is Nothing) Then
'// NB: If SpecFolder= 0 = Desktop then ....
If IsError(objFolder.Items.Item.Path) Then strFolderFullPath =
CStr(objFolder): GoTo GotIt
On Error GoTo 0
'// Is it the Root Dir?...if so change
If Len(objFolder.Items.Item.Path) > 3 Then
strFolderFullPath = objFolder.Items.Item.Path '&
Application.PathSeparator
strFolderFullPath = objFolder.Items.Item.Path '& Application.
'// User cancelled
GoTo XitProperly
GotIt:
BrowseForFolderShell = strFolderFullPath & "\"
XitProperly:
Set objFolder = Nothing
Set objShell = Nothing
End Function
> fire an exception.
> > OK Ken,
> > message
> > and
> > Chris
> > -----CODE START---> > Dim TheEmail As Outlook.MailItem
> > Dim Cats
> > CheckErr = False
> > Path", CurDir)
> > GoTo Step1
> > End If
> > Burn\Testers\"
> > ".msg"
> > Else
> > "Cancel Operation"
> > Exit Sub
> > End If
> > Step1:
> > Next i
> > GoTo Done
> > Error_Handler:
> > TheEmail.Save
> > Resume Next
> > Done:
> > End Sub
> > -----CODE END-----
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
oliv- How to select an mailitem in explorer with "show as conversation" Outlook VBA and Custom Forms 8
JorgeDario How to capture and save the text, when responding a MailItem? Outlook VBA and Custom Forms 3
JorgeDario how to check a MailItem has a digital signature (SMIME) with vba? Outlook VBA and Custom Forms 1
JorgeDario ¿What property of mailitem can be used like primary key? Outlook VBA and Custom Forms 6
C MailItem Find method doesn't work Using Outlook 0
G RE:The signature is also inserted if you touch the MailItem. Outlook VBA and Custom Forms 1
B Add signature to MailItem Outlook VBA and Custom Forms 3
C How can I create a new MailItem inside a user folder? Outlook VBA and Custom Forms 4
S Create a new Outlook MailItem in an Outlook folder(not a draft) Outlook VBA and Custom Forms 2
A How to get OOM MailItem Raw data Outlook VBA and Custom Forms 2
S Saved Property of MailItem is copied Outlook VBA and Custom Forms 1
S MailItem Find Method question Outlook VBA and Custom Forms 6
N Getting the attachments in MailItem Outlook VBA and Custom Forms 1
S ->[O2007] Parsing each line of a MailItem HTMLBody? Outlook VBA and Custom Forms 2
T How to get Inspector or MailItem from wordEditor Outlook VBA and Custom Forms 6
A Select the position of an attached file in a HTML mailitem Outlook VBA and Custom Forms 1
M MailItem object has no property for when a reply was sent Outlook VBA and Custom Forms 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
E Properties added to MailItem in ItemSend event visible to recipien Outlook VBA and Custom Forms 1
V Setting HTMLBody of new mailItem Outlook VBA and Custom Forms 1
V How to find mailitem in the inspector is a brand new one Outlook VBA and Custom Forms 2
M Activate "Add digital signature to this massage" on a MailItem? Outlook VBA and Custom Forms 1
K importing EML in MailItem Outlook VBA and Custom Forms 1
A mailitem Send issue Outlook VBA and Custom Forms 5
M Get email address from MailItem.To? Outlook VBA and Custom Forms 6
S UserProperties of MailItem object. Outlook VBA and Custom Forms 3
R How to capture a Mailitem Event Outlook VBA and Custom Forms 3
S get current position in message body of mailitem Outlook VBA and Custom Forms 8
S How to get RFC822 format message from the MailItem object. Outlook VBA and Custom Forms 4
D MailItem from an RSS feed Outlook VBA and Custom Forms 2
J Outlook 2007 crashed when pushing send on a displayed mailitem Outlook VBA and Custom Forms 1
N Memory with MailItem.Send Outlook VBA and Custom Forms 1
P Adding a button in a mailitem Outlook VBA and Custom Forms 1
D Max. length of MSO MailItem.EntryID Outlook VBA and Custom Forms 6
R MailItem.Display() error Outlook VBA and Custom Forms 1
R Clone mailitem Outlook VBA and Custom Forms 5
R MailItem Outlook VBA and Custom Forms 2
D Length of the MailItem.EntryID Outlook VBA and Custom Forms 2
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 1
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 5
