Addin Tabs and home ribbon
Ameneses
In outlook 2010 all my addin buttons are coming in Addin Tabs (listed in).
I dont want to always navigate to this tab to use my addins. So would like
to put all my buttons in the "Home" Tab of outlook 2010.
This did not happen in Outlook 2007.
Please advice
Roady [MVP]
The add-in will require an update for Outlook 2010 if it is to automatically
load its buttons in the Home tab.
You can File-> Options-> Customize Ribbon to modify your Home tab.
You can also right click on the add-in button in the Add-Ins tab and choose
Add to Quick Access Toolbar.
"Ameneses" <Ameneses> wrote in message
news:CF298605-DD5B-4F07-908B-D47EEFB4D2E5@microsoft.com...
> Hi,
> like
> Please advice
A Addin Tabs On Home Ribbon Using Outlook 1
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
Diane Poremsky Always Load an Outlook Addin New Slipstick.com Articles 1
D Constant Dropbox Outlook Addin Authentication Prompts Using Outlook 5
T client addin deletes all business contacts BCM (Business Contact Manager) 1
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
M Icloud Addin in Outlook 2013 Exchange Server Administration 9
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
P Addin / macro / rule to highlight email addresses outside company in To: field Using Outlook 3
H Outlook 2010 Antispam Addin Not Available Using Outlook 1
T Ribbion, AddIn Using Outlook 5
A Outlook 2007 addin does not load in other machines Using Outlook 1
R outlook addin error Using Outlook 2
G Error message - Outlook Backup addin is not a valid Office add-in Using Outlook 2
D Unable to activate social networking Outlook addin Using Outlook 1
A ActiveX component can't create object: 'VIA3OutlookAddin.Addin' Line No:8 Using Outlook 1
G Addin to show IMAP quota? Using Outlook 1
P getting rid of addin popup Using Outlook 6
J i need help regarding error message, 'Addin fax extention' issues in oulook 2007. Using Outlook 3
M Outlook Calendar Print Asst - Addin in Trust but doesn't show up in Calendar Using Outlook 1
J The add-in 'google Desktop searach outlook addin cannot be loaded and has been disabled by outlook. uninstall the add ins__ Using Outlook 3
S COM Addin Failed to load in Outlook 2003 Outlook VBA and Custom Forms 1
G Addin to define message format on a per-contact basis? Outlook VBA and Custom Forms 1
C Connecting to an addin in Outlook 2010 (or not) Outlook VBA and Custom Forms 1
V how to collect details from user, during installation of office addin? Outlook VBA and Custom Forms 1
A how to enable macro for addin Outlook VBA and Custom Forms 3
T Regarding Outlook addin Outlook VBA and Custom Forms 1
N Drag and drop attachment in outlook addin Outlook VBA and Custom Forms 4
S Outlook addin formregion as a drop down Outlook VBA and Custom Forms 6
K Attach addin to outlook 2007 editor Outlook VBA and Custom Forms 3
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
N Support for outlook 2003 addin in xp home sp2 Outlook VBA and Custom Forms 3
J Addin to trap email item open Outlook VBA and Custom Forms 2
R Hi, Ken, What should be noticed to avoid memory leak in outlook addin? Outlook VBA and Custom Forms 3
D Outlook AddIn can't load outside Visual Studio Outlook VBA and Custom Forms 1
T Shared addin using .net - deployment for non admins Outlook VBA and Custom Forms 3
T Simple MAPI send and Outlook COM addin Outlook VBA and Custom Forms 3
M VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp Outlook VBA and Custom Forms 1
U Outlook Addin Creation using Visual Studio 2008 Outlook VBA and Custom Forms 1
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
J Emails stay in Outbox forever once addin is loaded Outlook VBA and Custom Forms 3
C Problem installing VSTO AddIn on Vista Outlook VBA and Custom Forms 3
