Installing Exchange 2010 issue
John
I am going to test Exchange 2010....
I installed Server 2008 R2 on to a machine....installed all updates.
Installed DNS
Installed IIS
During teh Install of Exchange, i get 2 problems and cannont go any further.
When it is doing the "Readiness Checks" it fails on the Client Role
Prerequisites"
#1 Unable to read data from the MetaBase. Ensure the Microsoft Internet
Information Services is installed
#2 Unable to access the "Default website" on this computer
Then 1 error on the Mailbox Role Prerequisites
I went to teh site that it suggested to fix teh first issue, it gave me
instructions on how to install IIS for Windows 2000
John
http://social.technet.microsoft.com...0/thread/0aefcc92-dc32-40cf-bf24-341d41974d0e
I found the soultion:
Open Powershell with elevated rights using "Run As Administrator", and run
below cmdlets to install prerequisites...
a.. Import-Module ServerManager
b.. Add-WindowsFeature
NET-Framework,RSAT-ADDS,Web-Server,Web-Basic-Auth,Web-Windows-Auth,Web-Metabase,Web-Net-Ext,Web-Lgcy-Mgmt-Console,WAS-Process-Model,RSAT-Web-Server,Web-ISAPI-Ext,Web-Digest-Auth,Web-Dyn-Compression,NET-HTTP-Activation,RPC-Over-HTTP-Proxy
-Restart
c.. Set-Service NetTcpPortSharing -StartupType Automatic
(even though I had already set the NetTcpPortSharing as starting
automaticly. After I did step 2, teh system restarted and the NetTcpPort
was set at Manual. )
"John" <John@ivhs.us> wrote in message
news:%23tcos$FGLHA.5472@TK2MSFTNGP04.phx.gbl...
> Installed DNS
> Installed IIS
> further.
> Prerequisites"
M After installing Exchange 2010, how to get things to work????? Exchange Server Administration 1
W installing exchange 2010 with multiple forest (Cross-forest) Exchange Server Administration 2
D Installing SP1 for Exchange 2010 Exchange Server Administration 2
S Installing New Exchange 2010 Exchange Server Administration 4
C Installing Exchange 2010 SP1 in a Sub domain... Exchange Server Administration 5
C Now the problem I see is that I get an error when installing the Exchange 2010 SP 1. I attach a scre Exchange Server Administration 10
S Removal of Interim Update packages before installing any Exchange Server 2010 service pack Exchange Server Administration 1
A Error Installing Exchange 2010 SP1 on Exchange 2010 Exchange Server Administration 5
T Prerequisites softwares for installing exchange 2010 edge transport server on windows 2008 R2 Exchange Server Administration 1
C Installing a new Exchange Server with 2010 Exchange Server Administration 2
D Problem with installing Exchange 2010, AD problems? Exchange Server Administration 16
I Installing the first exchange 2010 with SP1 Exchange Server Administration 2
D Installing Exchange 2010 SP.1 - Domain Level Issues Exchange Server Administration 1
R Problem installing Unified Messaging on Exchange 2010 SP1 Exchange Server Administration 3
A Problem installing SP1 for Exchange 2010 Exchange Server Administration 8
C Installing Exchange 2010 on Windows Server 2008R2 domain controller Exchange Server Administration 3
V Installing/Configuring Exchange 2010 to Accomodate Sharepoint 2007 Exchange Server Administration 1
J Exchange 2010 SP1 upgrade error when installing mailbox role Exchange Server Administration 5
J MS Outlook 2010 Calendar connection to Exchange Server is broken after installing IE9_beta Using Outlook 3
R problem installing exchange 2010 sp1 -failed due to $error.Clear(); Exchange Server Administration 3
M Exchange 2010 SP1 fails during installing.... Exchange Server Administration 6
B Problem installing exchange 2010 (CAS Role) Exchange Server Administration 16
H error when installing sp1 of exchange server 2010 on and existing exchange server 2010 Exchange Server Administration 3
E Problem with OWA after installing Exchange 2010 in an Exchange 2003 Organization. Exchange Server Administration 6
S Exchange 2010 Management Powershell missing after installing SP1 Unable to load Exchange Server exshell.psc1 Exchange Server Administration 1
J After installing MOSS 2010 Exchange 2010 doesn't working Exchange Server Administration 5
D Can't delete items from OWA after installing Exchange 2010 SP1 Exchange Server Administration 7
D Error when installing Exchange 2010 SP1 at Mailbox role Exchange Server Administration 10
B Exchange 2010 Management Powershell missing after installing SP1 Exchange Server Administration 4
J Problem installing exchange 2010 SP1 Admin Tools Role Exchange Server Administration 19
G Hotfix requirements when installing Exchange 2010 SP1 - Help! Exchange Server Administration 8
C Error installing exchange 2010 in child domain Exchange Server Administration 11
C installing exchange 2010 into exchange 2003 without mail coexistance Exchange Server Administration 4
C installation error when installing exchange 2010 cas/hub in exchange 2003 org Exchange Server Administration 10
A Installing Exchange 2010 Server - Live Environment Exchange Server Administration 4
E Exchange 2010 migration from 2007 - problem installing Hub transport Exchange Server Administration 4
M After Installing ShrePoint Server 2010,'Initialization Failed' error raised when I 'm Complete the install Exchange Serve 2010 Exchange Server Administration 2
S Installing Exchange Server 2010 on Windows 7 Exchange Server Administration 4
J Error installing exchange 2010 Exchange Server Administration 13
X Installing new Exchange 2010 server and getting strange OU error Exchange Server Administration 8
S About installing Exchange Server 2010 Exchange Server Administration 10
J exchange 2010 error while installing the client access role Exchange Server Administration 7
A Installing Exchange 2007 Server into Org that only has 2010 Servers Exchange Server Administration 2
A Installing Exchange 2010 standard on windows 2008 standard Exchange Server Administration 4
S Installing exchange 2010 on 2k8 Exchange Server Administration 3
S Installing exchange 2010 on 2k8 Exchange Server Administration 5
M Issue after installing SP1 beta for exchange 2010 Exchange Server Administration 5
R Error while installing 2nd Exchange 2010 HUB Role in a multiple domain Scenario Exchange Server Administration 1
M Installing Exchange 2010 in child domain Exchange Server Administration 1
5 Installing new Exchange 2010 standard Exchange Server Administration 5
