Combining contacts and my address book info?
Bronzesculptor
I have 700 contacts with info and I have 800 in my address book. Many are not the same and I want one source with all.
Dineenp
I also have a problem with multiple lists under my "address book." When I click on Address Book, in the pull down menu I have four different listings, two that say "Contacts" and two that say "suggested contact." How can I combine all of these into one?
Russ Valentine
The Outlook Address Book view is simply showing you the Contact Folders you have created in your Outlook profile. You are free to combine and organize Contact Folders however you wish, but you do that in your Contacts view, not the address book view. Sounds like you need to decide you want to do that and then do it.
Russ Valentine
B Combining GAL + Personal Contacts in Address Book Using Outlook 1
mwh1962 combining pst & ost calendars & contacts with Office 365 Using Outlook 5
J Combining Contacts & Calendars for multiple e-Mail accounts Using Outlook 1
RBLampert Combining PSTs Using Outlook 1
D Combining date and time into one field Outlook VBA and Custom Forms 2
W combining outlook accounts Using Outlook 0
M How to set exchange calendar as default when combining with Internet calendar Using Outlook 2
D Outlook 2010 and combining multiple rules into one? Using Outlook 4
D Combining multiple messages into a single task Using Outlook 3
J Outlook 2010 Combining Rules for POP account and Exchange Account Using Outlook 4
N Combining Email Accounts into One Inbox Using Outlook 3
D Combining multiple e-mail address Inboxes? Using Outlook 3
J Combining data from two fields Outlook VBA and Custom Forms 3
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 3
GregS Exporting contacts Using Outlook 1
egarneau Meeting updates with external contacts (GMail) Using Outlook 1
bhamberg Contacts in a category Outlook VBA and Custom Forms 11
E GAL Attributes to Contacts Using Outlook 0
L Merge two contacts folders Using Outlook 1
N Gathering Calendar Appointments from Calendars that synced as Contacts Exchange Server Administration 1
W Migrating Outlook 365 Contacts & Calendar Using Outlook 2
N Two .pst files on one computer both with contacts? Using Outlook 9
S Import contacts to a shared mailbox Outlook VBA and Custom Forms 2
T Calender and contacts in trash Using Outlook 1
J what file contains contacts, tasks and appointments stored locally? Using Outlook 1
