syncing problems
C
carols.b
When I try to sync my mobile device with outlook 2010 beta - I get a message saying outlook has not been configured. Is this because it's a beta program? How can I get it configured to sync with my device?
Roady [MVP]
No, it's because your sync application requires an update to be compatible with Outlook 2010. Contact the supplier of the sync application and ask when they will support Outlook 2010.
If you are currently using the 64-bit version of Outlook 2010, you could try it with the 32-bit but in most cases the sync applications will still fail.
