Slow public calendar
Terry.Hoi
Environment
Email client: Outlook 2010
Email server: Exchange 2003
OS: tested on Windows XP and 7
Loading calendar under Public Folders took a long time. It was fast if I added the calender to Favorites and acces it from there.
Outlook 2003 and 2007 does not have such problem.
Do you know why?
Terry.Hoi
Will it be cached even if I am not using cached mode? I thought it will only be cached if I enable "Download Public Folder Favorites" under theCached Exchange Mode Settings.
Adding the public calendar to Favorites is just a workaround. I still want to find out why it is slow only when using Outlook 2010. Do you know the cause and fix for it?
