Oulook 2010 Journal and Tasks missing from Activities View
I
Inspired Phoenix
I just upgraded to Office 2010 from 07. My journal notes and tasks do not show up on my activities page on Outlook 2010 even though I have " All Items" selected. Only emails are showing up. This is a problem. Suggestions?
G
Guruprasad Ra
Did you try creating a new Outlook Profile?
Clickhere for help on creating new Outlook Profile. Once the new profile is created check if the issue still persists
I
Inspired Phoenix
Thank you for letting me know. How do I created enough pressure to have it changed?? This is an important part of using Outlook as an effective CRM. I have all my relationships set up in this model using this function.
Will old tasks and journal logs show up in Contact Manager if I move the card to it?
Instant search is found where? :):)
Tone2010
This is OUTRAGEOUS: What you are saying is that an absolutely crucial element of Outlook 2010 simply does not work!
Following your link shows this is not " by design" - it is by cockup.
Consider this an " uproar" from me.
There are plenty other flaws in 2010, but this is the worst so far.
Uproar here does little good - you need to open an incident with Microsoft support. I believe you get a free one within the first 90 days of installing the retail version of Office 2010 (I'll have to double check on this). If you work for a large corp, have your admin open the incident.
I'm not sure about the BCM question. I'm guessing No, but will need to test it.
Instant search is at the top of all folders where it says " Search [folder name]" - Ctrl+E will get you into the field.
I
Inspired Phoenix
Thank you again for any insight on how to resolve. I hope someone can figure it out. I was really looking forward to an improved newer version.
According to my contact on the product team, they are now labeling it " a known bug" and they do plan to fix it, but no word on when. (This status is changed from discussions during the beta when i was told it was " by design" .)
I
Inspired Phoenix
Thank you again and happy 4th of July! Funny how a simple shift to " known bug" seems better! If you could suggest to your contact to bump up the priority it would be wonderful. Regardless, lots of hugs to all of you for your support and time. I really like the idea that MS has the best going product out there and since so many of us entrepreneurs use Outlook and CM for our livelihood, it would like to have access to my years of information and tracking.
I
Inspired Phoenix
How is this known bug's resolution coming along. How can I encourage the solution to happen? :)
L
Linda Larkan
Thank you, Diane. Your information is extremely helpful. I discovered this issue with a client yesterday, and I suspected that it was a bug.
This is a feature that is critical for many users. Have you received any additional information on how this issue is progressing? Is there a way for the general public to check the status of bug fixes?
Once again, thank you so much for your help and commitment of your time.
Linda
Linda
SBCS TECH
Any resolution to this issue / bug ? I have a demo this week and this is a must show feature....... Thanks, John
No word on when it will be fixed.
L
Linda Larkan
Just checking back in to let the " powers that be" know that this is still top of mind.Linda
C
Cajun13
Any answers yet? If this issue is not resolved, how can I downgrade to 2007. This is ridicules.
SouthEssex
Operating System:Windows 7
I have just upgraded from Office professional 2003 to 2010 and have opted for the 64 bit version. One of the features of the 64 bit version is that it will not permit any earlier versions to run so I cannot re-install the 2003 version.
In 2003 I could add a journal entry to a contact, e.g. notes of a telephone call, and then, after opening the entry for that contact and moving to activies, I could see a list of all of the journal entries of telephone calls recorded against that contact and then open each entry in order to read the contents.
Since installing 2010 all of my telephone notes have been moved to the journal and the link to the actual contact broken. I can no longer see all of the telephone calls made to a contact and have to view them via the activities screen of my contacts.
How can I get all of my journaled telephone calls linked to the actual contacts against which the original entry was made.
For me it is a key feature of Outlook that I can record details of telephone conversations against a contact and to be able to re-view them later via the contact screen and not have to go on a long hunt in the journals which record all of my activies in Excel, Word, Access etc.
Is this another triumph for Microsoft!! They have a habit of removing features that users realy find useful and without telling anyone first. I used to use Microsoft Binder but that disappeared and Microsoft are in denial that it ever existed. Similarly the move from Word 5 to later versions resulted in a change to the way paragraph numbers work (or don't) which created problems for large documents using headers.
Does Microsoft ever listen to users of the products???
P Oulook 2010 very slow Using Outlook 2
P Problem: Favorites not persisting. (Oulook 2010) Using Outlook 1
J Oulook 2010 Shared Calendar Syncing Using Outlook 1
J Oulook 2007 Vs. Exchange 2010...always asked about login validation... Exchange Server Administration 9
T More Oulook 2010 Error Messages Using Outlook 1
F Oulook 2010 (on exchange 2010): "Cannot open this item" after search in online archive on indexed ma Using Outlook 2
P Oulook 2010 check spelling as you type not working. Word 2007 installed Using Outlook 9
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
M Following a refresh of computer (win8.0) conflicting oulook accounts Using Outlook 2
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
R Copy additional IMAP accounts into Oulook 365 Account Exchange Server Administration 4
F Difficult Oulook Crashing Problem Using Outlook 1
S Oulook view settings ( NO PST) Using Outlook 0
L Oulook Size On a Desktop Screen Using Outlook 2
L Oulook always "disconnected" how do I keep it open all of the time? Using Outlook 1
J Yahoo mail box does not open when I have oulook 2007 opend. Using Outlook 1
T Oulook is no longer downloading email from one of two of my gmail accounts. Using Outlook 2
R Search Oulook 2007 Future Appointment Using Outlook 1
B Using Oulook and have 2 accts. Admin acct gets other acct email as well. How do I stop? Using Outlook 1
R Oulook loses my personalized views Using Outlook 1
S Cannot get Oulook Scocial Connector to display properly Using Outlook 1
K how to check my official emails in oulook thorugh web? Using Outlook 1
B Multiple Oulook users in Windows 7. Using Outlook 1
J i need help regarding error message, 'Addin fax extention' issues in oulook 2007. Using Outlook 3
L Oulook 2003 Form upgraded to 2007 Outlook VBA and Custom Forms 3
F how do i set a reminder in onenote 2010 Using Outlook 8
