Rules Wizard - how to get OR instead of AND?
N
Nigel M
I've just switched to Outlook 2007 as Windows Live Mail is a pig wearing a pig costume at a pig party. I have previosly used Outlook 2003, and I'm pretty sure that you could specify that rules were ORed with each other rather than ANDed by clicking the word " and" .
For example, I want a rule like this:
if ((sender = fred) OR (subject = " pigs in space" ))
{do something}
The wizard creates rules with a hardwired AND, like this:
if ((sender = fred) AND (subject = " pigs in space" ))
{do something}
-- Nigel M
Z
Zohaib Ather
Hey Nigel,
I would be glad to help you out.
Two Methods:
Create two rules, one for sender and another for subject Create one rule only by the subject only
Hope it solves ur issue.
Regards,
Zohaib Ather | Microsoft Student Partner | Member of UGSS | Member of MSDN Community | Member of Microsoft Student Tech Club
Outlook Rules have never supported OR - Outlook Express (the predecessor to Live Mail) did.
You'll need to use two rules - one for sender is Fred, a second for subject is pigs in space.
Filters dialog supports OR when you use the QueryBuilder or SQL - but this is only used with Search folders, Views, Advanced Find, and Automatic formatting.
N
Nigel M
Really, it was that long ago! Oh well, I guess I'll have to use about 20 rules - the above was a simplification.-- Nigel M
Yeah, it would be a lot simpler and its a frequent request, unfortunately, its not possible in current versions. Maybe sometime...
