Re: PST has reached its maximum size. It will not allow me to delete files.
  • Thread starter ITsupportEngineer
  • Start date
I
ITsupportEngineer
i have the same issue, the pst file size is 2,06 GB and its no unicode, i migrate to windows 7 and then i tried to open it then i couldn't it will show the msg about the size and then the personal folder disappears, i tried the PST2gb tool and after truncking it i tried the scanpst.exe but every time it will give error. i don't have ana other tool to fix the file after trunking it..
is there any free tool to help with this?
Jim Chou
PST in non-unicode format will run in aover-2GB problem. Seeing this http://www.datanumen.com/aexr/problems/2gb-ost.htm
What u need to do is:
If you have Outlook 2003 or higher versions installed on your local computer, then you can convert the oversized OST file into a PST file in the new Outlook 2003 unicode format, which doesn't have the 2GB limit any more. This is the preferred method.
If you only have Outlook 2002 or lower versions installed, then you cansplit the oversized OST file into several smaller PST files. Each PST file contains a portion of the data in the original OST file, but it is less than 2GB and independent from each other so that you can access it separately with Outlook 2002 or lower versions. This method is a little inconvenient as you need to manage multiple PST files after the split operation. And you still need to face the headachy oversized problem when any PST file reaches 2GB later.
Use Advance Exchange Recovery can do this.
Hope to help.
Jim
A Outlook.pst has reached its maximum size Using Outlook 4
R Outlook 2007 to 2013 PST still has the 07 size limit not bigger 13 limit Using Outlook 3
J Lost contacts.pst afer sync with iCloud: where has contact.pst disapperaed to? Using Outlook 3
B "....pst cannot be accessed because another workstation has modified it. close and then restart all Using Outlook 1
D Pst File Has Continuous Errors Using Outlook 7
H PST Disappears - Backup PST disappears - newly generated PST has email from 2 weeks ago - what's happening? Using Outlook 2
K The file c:\...\Outlook1.pst cannot be accessed because another workstation has modified it. Close a Using Outlook 2
K Export Folder to PST Outlook VBA and Custom Forms 2
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 2
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S What's in a PST file? Using Outlook 1
N pst files are recreating automaticaly and cannot be deleted Using Outlook 5
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
N Two .pst files on one computer both with contacts? Using Outlook 9
DariTrevino MIcrosoft Outlook PST file cannot repair Using Outlook 1
E Exporting email (.pst) Using Outlook 8
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
semnaitik Archive PST is not empty but can't see old emails Using Outlook 2
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
E How to transform .OST in .PST ? Using Outlook 1
O Any decent tool to compare .pst files? Using Outlook 2
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
I Flagged emails in pst file corrupt to do list Using Outlook 12
O How to display number of items per .pst file Using Outlook 7
