Trying to move inbox emails from backup pc to primary pc in Outlook 2007
mbrewington
When I do an export of my inbox on one pc and then import on another pc, the email dates show up as none. How do i get dates to show properly
G
GordonBP
By not using the import/export function.
If you'd done even a tiny bit of research before starting you would have discovered that using the import/export function to transfer data between two instances of Outlook causes all sorts of problems, the least of which being that you have now very probably corrupted your Mail profile.
Create a new Mail profile as here, (ignore the WET bit) and then migrate your Outlook data properly as here.
If you find my response helpful, please click on the "Vote as Helpful" button!Thank you!My Blog
