Outlook stops responding. Using article 940226 I checked .pst and .ost file sizes.
JEH1
I discovered I have multiple .pst and .ost files--archive 7.9GB, archive1 265 KB, Outlook 1.675 GB, Outlook0 1.751 GB, and Outlook1 .744 GB. Are the multiple file causing performance issues and can i delete all but archive and outlook? I am using Outlook 2007 (12.0.6514.5000) SP2 MSO (12.0.6529.5000)
Ben M. Schorr [MVP]
Do you actually have those files OPEN in Outlook (look at your folder list) or just on your hard drive?
If you're having performance issues in Outlook there can be a number of causes - do you have Norton configured to scan your incoming e-mail? If so, you might consider turning that off. To turn it off with Norton, unfortunately, you'll probably have to uninstall Norton completely then reinstall it minus the e-mail scanning module.
How much RAM do you have in your machine?
What sort of performance issues are you having?
