Outlook 2010 is taking forever to open and load,
G
Grizzlebear
I just installed Office 2010 Pro and find that outlook takes forever to go though its start up and load. I have disabled most of the add-ins but it still takes an inordinate amount of time to open. (XP-64 Media)
Steven Moede
You might try renaming/deleting the .XML at:
c:\documents and settings\<userid>\application data\microsoft\outlook
Note: I might have the folder wrong since I use Windows 7. The other place it might be kept under WinXP from memory is:
c:\documents and settings\<userid>\local settings\application data\microsoft\outlook
the file is going to be <outlook profile name>.xml
the <outlook profile name>.srs file is your send/receive settings
Ruchi Bisht
Try the steps mentioned below:
1. Click Start->run (Windows key + R key) and type outlook /safe and click ok.
2. Check if you are able to open Outlook faster.
3. If it works disable add-ins from File->Options->Add-Ins click Go for COM-Add-ins.
4. Disable the add-ins.
5. Close and open Outlook again.
Ruchi Bisht
