Intermittent sending of email problem, restart of Outlook clears issue.
SteveComp3
I have a client with multiple PC's having this issue intermittently. I have had this problem in the past (years), and as I worked to find a solution, it happened to me again. This is not a new issue, nor is it an issue with the basic "setup" of the email accounts.
Intermittently, can be with a new email, or a reply, withor without an attachement, the mail will go to the outbox and this error will appear:
Task '(name of smtp server) - Sending' reported error (0x8004210B) : 'The operation timed out waiting for a response from the sending (SMTP) server. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).'
whatever email is in the outbox is now stuck, and new incoming email will continue to come in. the only solution to the problem is to exit Outlook, Ignore the question Outlook presents telling you you have email in the outbox and would you like to send it before you exit (if you try, it fails) and simply start outlook again. this immediately sends all email in the outbox.
In my, and my clients case, we are both using CA ITM anti-virus and spyware, WITHOUT the email scanner. We are not using any added software firewall. This is Windows XP pro, and the Outlook 2003 is SP3 (I remember this issue going back years with no SP and SP2). the account setup is for a POP3 server, and there is basic SMTP auth and no SSL. Pretty basic stuff.
I have found search responses suggesting corrupted account, bad account config, and problems with server. I have read to use the logging feature to find the problem, and when I do all it suggests is that Outlook does not even try to send the email. I have looked into my email server logs (we are NOT using exchange, its a POP3 server) and there is NO entry of any attempt to connect to my server and SMTP the email. I have even changed the SMTP server name in the account settings to the IP address testing if its perhaps a DNS issue. it appears to me to be a total lack of Outlook even trying to make a connection to the email server, even as it reports the error suggesting it had.
there are a few searches that specifically suggest the SP2 and SP3 upgrades had actually fixed this issue, but it appears its back. This problem has become a larger issue as the client does not realize the email had not gone out and it becomes a time sensitve issue. I have been trying to find a solution for weeks, and it appears to be an Intermittment Outlook problem.
Does anyone know of a solution?
K
Kathleen Orland [MVP]
What happens if you open Outlook in safe mode, does the behavour continue?
Start > Run > outlook.exe /safe
(note the space between outlook.exe and /safe)
Microsoft
SteveComp3
Kathleen,
I have not tried safe mode, as this is a working environment and while its hitting 6 or so of the systems, its quite intermittent, some users have reported having to restart Outlook 2 or 3 times a day, another that had the issue multiple times a day just a week ago, is now seeing it perhaps once every other day.
this client is vry stong in the need of their email, and asking them to try to operate in safe mode (in Outlook) may be a hardship. I did have a user create the error log for me, and I found once the problem starts, Outlook just never seems to try to send the email, even though if you try to exit it asks if you want to send the email first. the fact an attempt was not being made was also noticed at the email server.
SteveComp3
Hal,
good thought, I have been running a continuous ping with the maximum MTU size for the last 20 minutes from their netwrok to mine (this is where the email server is) and so far aside from a very few drops, the MTU proves to be 1500, and I am having no issues.
this would still not explain why simply exiting and restarting outlook would clear the outbox and send all the email wihout fail, everytime. If there really was a blackhole router, I would assume this would not be the case.
I had experianced this issue a while back myself, and others mentioned the same thing. Since we could all simply restart Outlook I never really worried about it. This client however is having issues with it due to the timely nature of some of their email. I have always considered this an Outllook problem, and am suprised there is not much on it.
Somasundaram Pandiaraj
Rename the send/receive file (.srs) from the location mentioned below and verify the issue.
drive:\Documents and Settings\<user>\Application Data\Microsoft\Outlook
E Multiple, intermittent Outlook 2010 errors Using Outlook 12
G Outlook Intermittent Issue with Drafts not Displaying Entire Content Using Outlook 4
K Intermittent ability to send to single domain. "Connection refused" Exchange Server Administration 1
E intermittent "Your imap server closed the connection" messages Using Outlook 6
C New mail icon on taskbar intermittent Using Outlook 1
T Problems WinRM on Microsoft Exchange Server 2010 - Showing errors then success messages intermittent Exchange Server Administration 4
D Intermittent Connection Between Outlook '03 and Exchange '03 Using Outlook 5
G A problem with intermittent Outlook connection Using Outlook 1
D Sending email from Office 365 alias in Outlook Using Outlook 4
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
R Warn before sending message Outlook VBA and Custom Forms 4
HarvMan Hotmail - Sending email is undeliverable Using Outlook 4
A Sending contact vcards sends older version instead of updated version Using Outlook 4
M McAllister Outlook stops Sending/Receiving/Synching after disconnecting remote desktop session Using Outlook 2
B When sending an email, I am showing 2 of my address's Using Outlook 1
A Check for words in subject header before sending email Outlook VBA and Custom Forms 4
W Sending To Wrong Account Using Outlook 15
H Select Specific Account When Sending Email, Based on Current Folder Outlook VBA and Custom Forms 1
M MsgBox when not sending from specified account Outlook VBA and Custom Forms 2
R Sending emails via Outlook XP, from Windows 10 File Explorer Using Outlook 1
L Creating drafts when I thought I was sending Using Outlook 1
C address book "when sending email" bug? Using Outlook 0
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
A Sending Emails Through Outlook From Multiple Email Addresses Using Outlook 1
P Outlook 365 sending intermittently Using Outlook 0
C How to avoid sending mail to the wrong contact person New Slipstick.com Articles 1
V iCloud Calendar invitations not sending Using Outlook 3
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
latitudeit Outlook for Android - Sending from an alias address Using Outlook 2
A How to get rid of "sending on behalf of" when sending from Outlook 2016 client Using Outlook 12
Diane Poremsky Automatically create a task when sending a message New Slipstick.com Articles 0
P Categorise emails on sending - macro not working in Preview mode Using Outlook 1
Diane Poremsky Outlook is sending winmail.dat attachments New Slipstick.com Articles 0
Diane Poremsky Select from a List of Subjects before Sending a Message New Slipstick.com Articles 0
Diane Poremsky To delay sending a message in Outlook New Slipstick.com Articles 0
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
