Problem while importing a certificate
  • Thread starter riochicken
  • Start date Views 768
riochicken
I;ve just installed Exchange 2010 on a Windows 2008 server and when I trt to import my officially certificate with Windows Powershell, it gives me an error:
[PS] C:\Windows\System32>Import-ExchangeCertificate -Path "C:\cert\certs\www.mydomain.crt.csr"
Import-ExchangeCertificate : The source data is corrupted or not properly Base64 encoded.
At line:1 char:27
+ Import-ExchangeCertificate <<<<  -Path "C:\cert\certs\www.mydomain.crt.csr"
    + CategoryInfo          : ReadError: :)) [Import-ExchangeCertificate], InvalidOperationException
    + FullyQualifiedErrorId : 76D5CB03,Microsoft.Exchange.Management.SystemConfigurationTasks.ImportExchangeCertificate
I rekeyed this certificate from the certification authority (godaddy.com)
Does anybody have any idea?
Thanks in advance!
Kind regards
Richard
Andreas Helland
Are you importing the correct file? The .csr suffix sounds like the request, not the final cert? (Though I do not know what naming convention you use for your files.)
You should be able to open the certificate in Notepad, and it will say something like "BEGIN CERTIFICATE", followed by a long base64-encoded string, and "END CERTIFICATE". Did you choose the IIS format when fetching the cert from GoDaddy?
Brian Day MCITP [MVP]
See if it actually did import regardless of the error. There is a known bug being worked on where you will see that exact error, but if you try the Enable-ExchangeCertificate CMDLET it'll work or if you look in the GUI you'll see it there. It seems to be cosmetic only.Brian Day / MCSA / CCNA, Exchange/AD geek.
riochicken
First of all, thank you for your reply!
I filled in all of the necessary details at godaddy.com and downloaded the signed certificate, which is a *.csr file and a *.p7b certificate to state godaddy is a trusted certificate blabla, so I presume (allthough I know assumption is the mother of all f*ckups ;-)) this is the right file to use! And yes, it starts with the Begin Certificate like you state in your reply... :(
Richard
riochicken
Thanks for your reply!
I tried to enable the certificate but it doesn't work! It gives me an error stating that the certificate with the given thumprint could not be found... I als tried to install a self signed certificate btw and that also failed with the same error as described above in my starting mail... :(
Error:
-------------------------------Enable-ExchangeCertificate : The certificate with thumbprint D6592AC9F473BE7225BD1E5D5C99DD807B4AA126 was not found.
At line:1 char:27
+ Enable-ExchangeCertificate <<<<  -Thumbprint D6592AC9F473BE7225BD1E5D5C99DD80
7B4AA126 -Services "SMTP, IIS, POP, IMAP"
    + CategoryInfo          : ObjectNotFound: :)) [Enable-ExchangeCertificate]   , InvalidOperationException
   figurationTasks.EnableExchangeCertificate
--Thanks!
Richard
