Active directory response: 00002098: SecErr: DSID-03150BB9, problem 4003 (INSUFF_ACCESS_RIGHTS), dat
H
HSC-TSA
We are running a coexisting environment (Exchange 2003 & 2010), when I try to move a user mailbox from Exchange 2003 to 2010 I get the following error:
Summary: 1 item(s). 0 succeeded, 1 failed.
Elapsed time: 00:00:01
Abc Xyz
Failed
Error:
Active Directory operation failed on Domain.Name.Kw. This error is not retriable. Additional information: Insufficient access rights to perform the operation.
Active directory response: 00002098: SecErr: DSID-03150BB9, problem 4003 (INSUFF_ACCESS_RIGHTS), data 0
The user has insufficient access rights.
Exchange Management Shell command attempted:
'Domain.Name.Kw/VPO/Staff/Users/Abc Xyz' | New-MoveRequest -TargetDatabase 'FOD'
Although, I'm performing the task by a user that is a member in " Domain Admins" and " Organization Management" groups.
Any solution will be appreciated.
Regards
H
HSC-TSA
I had this problem also but I took some guesses and tried with resetting the permissions on the user object in AD which actually did the trick.
http://www.msexchange.org/articles_tutorials/exchange-server-2007/management-administration/exchange-2007-issues-mailbox-management.html
The last paragraph in that article sums it up. This is actually very much the same as the OWA logon issues for users who did not have inheritage on their object.
Vegard
It did the job!
The user used to be domain admin.
Thanx
K
ktpelt
I received this same error but now can't try to move the mailbox again because it says the user is in the queue. When I try to remove the user from the move-mailbox queue is doesn't let me.
Andy Landen
I have an account that I am trying to move from Exchange 2010 back to exchange 2003 & I get this error:
FailureCode : -2146233088
FailureType : UpdateMovedMailboxPermanentException
FailureSide : Target
Message : Error: An error occurred while updating a user object after the move operation. -->
Directory operation failed on phdc4.peacehealth.org. This error is not retriable. Additional information: Insufficient access rights to perform the operation. Active directory response: 00002098: SecErr: DSID-03150A45, problem 4003 (INSUFF_ACCESS_RIGHTS), data 0 --> The user has insufficient access rights.
I checked the referenced link above & the inheritance issue does not apply. Just for grins & giggles, I unchecked it & re-checked it & ran the move again - same error.
Exch 2010 SP1 Rollup 1.
Any other ideas?
S Active Directory Management Tools for Administrators New Slipstick.com Articles 0
Diane Poremsky Import Images into the Active Directory New Slipstick.com Articles 0
S How to send an OUTLOOK task to a contact out of my active directory? Using Outlook 2
J Setup mail for Exchange 2010 through Active Directory on Server 2008 R2 Standard Exchange Server Administration 3
T Copied Contact Does Not Update With Active Directory Information Changes Immediately. How Do I Force Update? Using Outlook 1
B Re: Exchange OOF / EWS Problem - The user and the mailbox are in different Active Directory sites Exchange Server Administration 0
D how to give perrmission on calender to user in ACTIVE DIRECTORY Using Outlook 0
T The Microsoft Exchange Active Directory Topology service on server localhost can't be contacted via Exchange Server Administration 2
P Will 'ldap modify' command work on some Active Directory fields? Using Outlook 2
E Event ID 9514 - Two objects in Active Directory have the same proxy address Exchange Server Administration 3
C Active Directory error applying Exchange 2010 SP1 Exchange Server Administration 4
O Exchange 2010 Service Pack 1 Active Directory Schema Exchange Server Administration 1
T Active Directory domain 'FECR' has an unrecognized Exchange signature. Current DomainPrep version: 1 Exchange Server Administration 2
R creating 1 casarray with multiple active directory sites Exchange Server Administration 10
C OWA 2007 New Message Error - Outlook Web Access was unable to access the Active Directory resource Using Outlook 2
C Active Directory does not exist or cannot be contacted Exchange Server Administration 12
C Multiple Domains in one Active Directory Structure Exchange Server Administration 4
A Exchange Server 2010 and Active directory 2003 Exchange Server Administration 5
L How to cleanup active directory after failed Exchange 2010 mailbox role server installation? Exchange Server Administration 5
B The Microsoft Exchange Active Directory Topology service on server localhost can't be contacted via Exchange Server Administration 3
V Active directory users not appearing in Global address list Exchange Server Administration 8
F SMTP Relay to Remote Active Directory Site Exchange Server Administration 4
T Exchange 2010 servers can't communicate with Active Directory Exchange Server Administration 4
B Active Directory Preperation Problems Exchange Server Administration 8
V Upgrade Exchange 2007 to 2010 Active Directory virtual list view Exchange Server Administration 3
S Exchange OOF / EWS Problem - The user and the mailbox are in different Active Directory sites Exchange Server Administration 16
P Automate Outlook Start - No Active Explorer Object Found Using Outlook 10
E Outlook rule only active certain times of day Using Outlook 6
R HELP!!! Email template with active excel spreadsheet Using Outlook 1
C active/passive broadband connections to maintain various IT services Exchange Server Administration 2
R Went from outlook 2003 to 2010 - can't retrieve active for contacts Using Outlook 0
W active sync Using Outlook 2
E Using with Active Sync, Outlook become unresponsive Using Outlook 5
M 'Send link by E-mail' doesn't provide active link.__ Using Outlook 1
J When a database move from active host in a DAG, user are prompted for credentials Exchange Server Administration 8
D Using Inbox as 'Active' tray, with both incoming and 'sent' mail, with senders and receivers displayed. Using Outlook 1
U Outlook 2010 Ignore Conversation Feature, list of Active Ignored Using Outlook 1
J OWA not working when active database moved Exchange Server Administration 3
S Web Links are not active when using Outlook Web Access 2007 Using Outlook 1
P How can I convert an Outlook 2010 folder to a .pdf with active links like I could in Outlook 2007? Using Outlook 3
S Active Passive DAG seperate DNS namespace Exchange Server Administration 7
B Active Active Site Resilience Exchange Server Administration 3
K publish exchange active sync behind TMG Exchange Server Administration 4
S Active Sync Device ID Using Outlook 2
E Transfer calendar from a .pst to a user's active exchange account? Using Outlook 7
M Active Manager operation failed to mount DB Error Id: 50A399C7, ErrorId: BF128831 Exchange Server Administration 10
P Ex2010 active sync Exchange Server Administration 4
R Hi, Is Outlook 2010 compatible thru active sync with Windows Mobile 6.1 Professional. Using Outlook 4
F Active Sync proxying not works in a Exchange 2010/2007 Coexistence Exchange Server Administration 1
