What happens to programmatic access via MAPI if the per-mailbox MAPI setting is disabled in EMC
  • Thread starter Ken Gartner
  • Start date Views 617
K
Ken Gartner
Folks, I noticed that in the help topic listed as 'Enable or Disable MAPI for a User Mailbox' one can disable MAPI access per mailbox.  Is this primarily meant to prevent the user from using an Outlook client or does it effectively prevent *any* kind of MAPI (ie, programmatic) access to the mailbox?  For example, will MAPI code that creates a new mail message work properly if this MAPI field is disabled?
Regards,
Ken Gartner
