Problem with Exchange UM Message Waiting Indicator MWI
Jan K Andersen
Dear all,
We are having a problem with the MWI (message waiting indicator) not being generated/sent by Exchange 2010 UM?
Please could someone confirm the different steps needed for Exchange 2010 UM to generate the SIP NOTIFY messages (I assume that's how it has been implemented)? We receive the e-mail notifications everytime someone leaves a voice-mail - so I assume that we are setup correctly?
Our setup is simple, we have a SIP Server which will accept the SIP NOTIFY messages (if they just arrived) and forward them to the different Polycom phones registered with the SIP Server - we have created the dial-plan and gateway etc for the SIP Server and we are able to place calls into Exchange 2010 Subscriber Access.
Kind regards,
Jan
James-Luo
In order generate a SIP NOTIFY message, the Mailbox Assistant of the mailbox server need to query AD to register for appropriate notification at first. After the Mailbox Assistant receives mailbox notification, it maintains in memory state and determines if the MWI state of the users has changed.
If the MWI state of the user has changed, Mailbox server will proxies the information/request to the UM server within the site. The UM server encapsulates MWI state change information in a SIP NOTIFY message and forwards it to an appropriate gateway
So, please capture the network traces from UM server to IP GW, and check if the SIP NOTIFY is sent properly, you can use WireShark, or Network Monitor
James Luo
Jan K Andersen
Hi James,
Done the trace on the UM server going to and from the IP GW using Network Monitor - however, I can only see that the UM server sends SIP OPTIONS across the wire for which the IP GW replies correctly with 200 OK? Any ideas - maybe I haven't setup someting correct, but all I could find in the documentation is that we simply just "tick" the box saying Enable MWI etc :)
Kind regards,
Jan
James-Luo
Yes, the reply should be 200.
Does the issue happen to all users?
How"s the SIP NOTIFY from UM server? Does “Messages-Waiting” flag to “Yes”?
James Luo
Jan K Andersen
Hi James,
I have not seen any SIP NOTIFY being forwarded to the IP GW for other users with pending voice-mails either?? I am currently trying a fresh install in another lab to see if there are any configuration issues with the environment. The new lab will use a resource forest which I assume shouldn't be any problem with MWI?
I will report back my findings when I've tested the new lab later today :)
Also, have you found any detailed technical documentation on how it should work - all I can find is high-level.
Kind regards,
Jan
Q
Quinalt
I'm having the same issue. Wireshark trace analysis shows options requests and responses from our mitel 3300 and exchange 2010, but no NOTIFY messages are being generated by the Exchange Server. The MWI box(es) are set to enabled on the Exchange server and no events appear in the the Event Log.
Anyone have any ideas?
P
Philippe _CH
I have the same issue with Exchange 2010 UM and CS1000. In the mnetwork trace is no Notify from UM to IP gateway.
MWI are cheked in policy and in Gateway params.
M Problem setting up exchange account Using Outlook 1
S Internet Mail SMTP Connector Problem on Exchange 2010 after Migration Exchange Server Administration 2
V Exchange 2010 - problem sending mail from one server Exchange Server Administration 5
B Re: Exchange OOF / EWS Problem - The user and the mailbox are in different Active Directory sites Exchange Server Administration 0
S vb.net exchange 2010 problem with enable-mailbox command Exchange Server Administration 2
A Exchange 2007 <-> 2010 OWA not working together redirecting problem Exchange Server Administration 1
P Exchange 2010 Installation Problem Exchange Server Administration 9
D INSUFF_ACCESS_RIGHTS problem with Certain Settings Exchange 2010 Exchange Server Administration 4
B Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 15
M Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 2
I Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 4
J Exchange 2010 / 2003 OWA Problem Exchange Server Administration 2
A Problem Setting up Outlook Anywhere for Exchange 2010 Exchange Server Administration 17
U Exchange 2010 Recovery Database: WMI Problem? Exchange Server Administration 3
R Problem installing Unified Messaging on Exchange 2010 SP1 Exchange Server Administration 3
T Exchange 2010 SP1 Mailbox export date filter problem - bug? Exchange Server Administration 9
M SendMail problem with ActiveSync 14.0 (Exchange Server 2010) Exchange Server Administration 3
S Exchange OOF / EWS Problem - The user and the mailbox are in different Active Directory sites Exchange Server Administration 16
M Problem with meeting requests (default reminder set to 15 minutes by Exchange) Exchange Server Administration 4
M Is there any problem in installing MS exchange server in India with SMS sysnc options enabled? Exchange Server Administration 3
P SBS2008 / Exchange with POP3 Connector / Invalid Header Fields -problem Exchange Server Administration 20
